Hi all , have had a few minor dramas setting up cam switching with a ViPec plug in . Is the best way to make up a table of MAP vs revs and run with the solenoid switched off up to say 3000 revs and 100 kpa (atmo) pressure ? Mine had been using a TPS vs revs table and that created drivability problems .
I set up a MAP/revs table which is off up to about 1600 revs and the off/on divide is sort of a diagonal line from 120 kpa at 1600 revs to around 0 kpa at 4000 revs . Its not really linear more a curve with its radius facing the lower RHS of the table if that makes sense .
Referencing off TP cost lots of off boost torque and fingers crossed I'll get better fuel consumption if not booted everywhere .
It's surprising how wild 256 Tomeis get with the solenoid on at very low revs , no hope of idling anyway .
Also it's set to switch off at all pressures between 4690 and 4700 revs .
Sorry if a silly question but I migrated from a PFC and you had no choices in this area , you did the idle learn and hoped it sorted itself out . Hopefully this is where I get the consumption back I had with the Apexi .
Realy like the versatility of the ViPec but it's a learning curve , cheers Adrian .
Easiest way is off a GP output then put your desired parameters (Rpm>1100, tps> 5% or whatever)
I forget which digital output it is but it is shown in the help section somewhere (in the wiring section)
Hope this makes sense. Im going from memory.
its AUX 1, set it to gp output.
Condition 1 and 2 - (OR 3)
SC 1: rpm> 1400
SC 2 rpm< 4000
SC 3 map< 180
start with this and then fine tune it to how you like it.
basically this is setup so its off on idle, then at 1400rpm to 4000rpm it will be on until the map goes over 180kpa where it will switch it off.
hope this helps
This is what I'm using and it seems to work quite well . It feels much better at part throttle for most of the sub atmo 2-3000 rev area and the 4 across the middle of the top row is an attemp to lose the closed throttle kick/buck I'm get in this area when cold . I think the cam switching and throttle closed fuel cut resumption were fighting each other in the 1400-1600 rev area .
I guess it makes sense to get the best trapping efficiency (shortest overlap period) at light loads and aside from a bit more torque in this area I could use better fuel consumption numbers too . My consumption yardstick is how far I get before the needle drops to the top line from full to the neck - which is real scientific is't it . Better than 50 is reasonable and better than 100 by the first 1/4 has been hard in the past .
A .
Edited by discopotato03
Can you post a video of how wild the tomei 256's sound disco? I have a vipec plugin myself. Can you go into a little more detail on what your actualy setting up doing.? I'm very new to all these awesome vipec capabilities lol.
My tuner did it while I was with him once , its really only around idle up to dunno maybe 13-1400 revs . Best comparison I can give is trying to make a engine with full race cams idle too slow . Wild shaking and constant stalling . You wouldn't go there intentionally if you didn't have to .
I'm guessing std cams do a similar kind of thing with the sloenoid switched on at idle .
The main issue is engine characteristics change if the solenoid switches at the wrong times , obviously too much valve overlap costs you part throttle off boost torque because the inlets close too late and the exhausts open too early . Once the gas speed is up a bit its better able to flow in the right directions .
I also look at RB25DETs as a lowish CR engine off boost and they seem to work best with conservative valve timeing for normal part throttle driving .
When my PWM table was referencing off throttle position there was no way to have the solenoid off up to 100 kpa/atmo pressure into the 2-3000 rev range (see table above) and with it on the overlap timing was to much to allow it to make best torque in these areas . It didn't really run camy or rough but it didn't feel sweet and at times a little breathless . Now its very smooth and has more torque meaning you open the throttle less just getting around . It made a big difference to the cold start and warm up characteristics meaning it drives a lot nicer initally now .
I am also starting to lean out some parts of the sub atmo pressure fuel map because I had it a tad rich in these areas looking for better part throttle performance .
I'll know later today how the consumption looks and theory suggests it should be better . Anything that improves fuel consumption (E70) and gains torque at the same time is all cake I reckon .
Cheers A .
Just as an update the consumption ended up ok but it drives better overall . I also changed the accel load table from MAP to TPS and I think thats going to work better overall too .
Do we have a Vipec/Link G4 plug in tuning thread here or do we want one ?
Cheers Adrian .
    • well mate, while I hear your pain, turns out I don't feel it this time! Must have been a bastard of a job crammed into the boot The tank was very empty (probably pumped out, not dropped and drained because there were some fumes still) and in very good condition internally. I'm sure he never ran e85 in it I don't know what the hell Nissan's fuel tank engineers were thinking about their clipping system, this hanger was really hard to get moving but came out in the end All looks very good (as I'm starting to hopefully expect) and Matty was right it is an 023 (044) bosch which should be plenty for the injectors and turbo
    • Saturday 8th February 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Thursday 6th February 8pm. Supp Regs: TBC Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. email [email protected] To compete in this event you will require A valid AASA General speed licence Or (Day license is $35.00 via the AASA Website) MA licenses no longer accepted A helmet, long sleeve clothing and it is reccomended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs Above. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Entry Link >> https://www.sauvic.com.au/entry/deca/20250208 Entry List: 1. Martin Sullivan 2.  3.  4.  5.  6.  7.  8.  9. 10.  11. 12.   13. 14 15.  16.  17.  18.  19. 20.  21.  22.  23.  24.  25. 26.    Reserve list 1.  2.
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
