Up forsale is a 1/16 Traxxas Ken Block Gymkhana Fiesta VXL Brushless (#7309) Current new Model with new TQi 2.4Ghz
i can assure you the car is in excellent condition and drives great, only used a couple of times, Heaps of power! Drifts and power slides like crazy!
Check out the performance with someone driving the same car on youtube with 2s Lipo same as what im giving
& 3s Lipo
If you change the gearing you can easily make these cars hit speeds over 65mph +
Fully assembled, Ready-To-Race®, with TQI™ 2.4GHz Digital radio and painted body.
standard NMIH 1200mh battery pack,Wheel removal tool,Manuals & Box
Extras which i purchased
*7.4v Lipo Battery 1800mah Fullymax 25 -50c , only used twice. Cost $40
* Traxxas Hopup 7018X Aluminum Pushrod set with pivot balls, Still have not installed, Cost $40
*New Drift Slick tyres which have about %90 tread left all around. Cost $25
As usual with hobby you will need to purchase your own lipo charger, can get chargers for about $15 on ebay.
Spent over $650 on this package
Asking $400 firm for the lot, Pick up from Glenroy Melbourne or can post Australia wide for an extra $20 Registered post.
Call or sms:0422756270. Cheers.
Features include:
Officially licensed Ford Fiesta body design and Ken Block/Monster Energy graphics
Officially licensed Volk Racing TE37 wheels (1.9” diameter, 12mm hex)
Unique green pushrods and toe links, exclusive to the Ken Block Gymkhana Fiesta
Pre-glued, low-profile Gymkhana-compound slick tires molded in a pecially formulated rubber compund for authentic Gymkhana performance and handling
Impact absorbing foam front bumper
Adjustable height body mounts
Powered by the Velineon® Brushless Power System
Traxxas High-Current Connector allows high-capacity battery packs to deliver maximum voltage to the Velineon Brushless Power System
Velineon VXL-3m Electronic Speed Control
-LiPo, NiCad, and NiMH compatible with two-stage low-voltage detection
-Sport Mode – Forward / Brake / Reverse
-Race Mode – Forward / Brake
-Training Mode™ - 50% Forward / Brake / 50% Reverse (patent pending)
Velineon 380 Brushless Motor
-High-performance sensorless design
-High-strength Neodymium magnets
-Efficient, high-speed ball bearings
-Precision-balanced rotor
-Gold-plated 3.5mm bullet connectors
Digital High-Torque Waterproof Micro Steering Servo
Waterproof, o-ring sealed receiver box
Sealed, silicone-filled differentials—an industry first in 1/16 scale
Torque-Control™ slipper clutch system
Telescoping universal-joint driveshafts
Rubber-sealed ball bearings
External gear cover with easy slipper access
Rocker-actuated shocks provide true progressive damping and spring rates
Threaded-body, oil-filled shocks permit fast, precise preload adjustments and deliver smooth, consistent damping
Suspension is precision tuned for on-road performance
Fiber-composite monocoque chassis
Speed control and receiver are securely fastened to chassis
Integrated battery compartments with intake and exit cooling vents
Quick-release battery doors for fast pack changes
Edited by G4orce
    • Hi guys, Sorry to butt in and take it slightly off course, although still on the VCAM subject.  I had VCAM put into my Tomei 2.8 bottom end and I struggle to take off because the engine has very little torque caused by VERY low dynamic compression at 60psi. But once off the mark and especially on boost, the engine rev happily all the way to 8000rpm and makes 630hp at 20psi of boost on E85 at the rear hubs. Has anyone had any similar experience or any suggestions on what might cause this low compression at low rpm? I am in the process of converting it into a 8hp transmission and with this low torque, the engine would not even stay running until the throttle is opened to more than 30% and then I loose all vacuum.
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
