yeah the n1 model works 100% with the s13 ECU. As long as you have the consut plug still on the loom you can simply plug it in and start playing.
Otherwise, if the plug isn't there, i can make one for you without the proper Consult connector (but a standard 5 pin plug) and some extra wire so you can tap it into the ECU wiring yourself.
Let me know how you prefer it.
Impakt
  • Replies 269
getting very interested and will most definetly purcahse one soon.
but, a couple of questions first.
have u found out if the blue backlit screen is feasible? and the total cost?
also, you have said there are provisions for 7 analogue inputs, what about the standard boost guage on the R33 gts-t. would it be possible to use it as an input?
Thx again,
Bill
Yep , got it two days ago. absolutely awesome mate. love it. have already run it through mine and me mates car and trying to figure out how to mount the bastard :)
  • 3 weeks later...
Are you sure that you wouldn't be able to make this unit display / clear fault codes?
I have a laptop and can do it via Conzult / Datascan, but I don't always have a laptop with me. Would be much easier via this wonderful unit...
yeah i can add the feature to view and clear fault codes, but i wont invest the time to do it unless the demand was there.
I'll add you to the (new) list of ppl who wuold buy one if this feature existed :D
I'll add you to the (new) list of ppl who wuold buy one if this feature existed :)
Thanks!
  • 1 month later...
  • 4 weeks later...
Update: I'm currently working on a Subaru (OBD-I) equivalent, and in the meantime thought i would add a fault code read/clear function to the Nissan one!
Price will still be the same and existing displays can be upgraded.
PM me if you're interested!!
Impakt
  • 2 months later...
Hi Impakt,
i bought one of these off you aaaages ago (like, a year and a half ;)) i was wondering if there are any software upgrades or anything like that that have changed over the years of you making them, or are they still the same as when you started?
Mate would you believe they are still the same? A bug is yet to be found ;)
I mentioned adding features to see if it would get demand going again but it didn't so for now any upgrades are on hold.
Lately i have been spending my spare time getting the SubDataScan going..
Impakt
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
