  • Replies 269
guys, i have been in touch with crystalfontz about this ...
here is what i found...
I use their software on my pc to display motherboard monitor stats, all very useful, and works perfectly with any hd44780
anyway ...
I was looking at :
http://www.crystalfontz.com/products/2004a...#CFAH2004ATMIJP
but didnt want this type of blue screen, so asked them directly if this :
http://www.crystalfontz.com/products/1602l...#CFAH1602LTGHJP
type of colour screen was available in 20x4 .. and it is !!!!
hoorah !
below is the reply i had from them regarding it :
Obviously it does work out to be slightly pricey, but you get a screen that is a very close match to the standard dash colours. They are also just standard hd44780 lcd modules that are a direct replacement to impakts screens. Have a look at
http://www.crystalfontz.com/products/index-std.html
any of the 20x4 screens will be a direct replacement if you so wish, and would take about 15 mins to swap them over i rekkon...
here is the mail :-
This is not a stocked item, but it can be ordered.
Here is the pricing information. Lead time is 6-8 weeks for < 1000, 8-10 weeks for > 1000.
CFAH2004L-TGH-JTW
Pricing:
1-9: US$59.52
10-19: US$46.77
20-49: US$40.48
50-99: US$36.12
100-199: US$32.15
200-499: US$29.3
500-999: US$25.51
1000-1999: US$23.96
2000-2999: US$22.94
3000-4999: US$22.69
5000-9999: US$22.18
10000+: US$21.71
Discounts are based on per-order/per-shipment. For example, 10K units shipped as a 1K order per month for 10 months qualifies for the 1000 piece price.
International orders must be paid in advance by wire transfer.
Please let me know if you have any questions.
Yotis: No idea whether it will work on the R34. AFAIK they have an OBD-II connector, and not sure if they support the CONSULT I protocol.
tang0: Glad you are happy. Atm i only have 1 left!
Impakt
Ah ok.. if anyone from gold coast or brisbane area purchases one from you impakt, could you forward my enquiry to them? Would b interested to see if it works with my car. :cheers:
Cheers,
  • 1 month later...
Update: I have ordered some more parts and will have 10 more displays ready to go in a couple of days. 3 or 4 people are already showing interest in this batch of 10 also.
Impakt
If you wish to test it out on a GTT, PM me :)
From what I've seen yes it uses Consult-II as opposed to Consult-I but that's just for actually diagnosing codes and altering data on-board the ECU. But they both use the same base OBD-II language whcih should decode as normal.
Either way I think it's worth a shot just to plug it in and see.
BTW Ed where is the Consult connector in the 34? Just had a quick look around the fuse panela nd couldn't see it????
Should be below the little pocket compartment to the right of the steering column.
Let me know if you need me to take a pic.
Ahhh below the pocket..about the only place that I didn't look :P
I e-mailed Pete from PLMS developments, he said someone with an R34 has ordered one of the interfaces to try...so I'll let you know how it goes when he get's back to me.
Dan
Have you worked out yet how to pull the maps out of the ecu. I'm asking because I've got a r32 gtr mines chipped ecu (glued in chip) and I want to pull the map out of it and knock a little timming of the top rpm points and add a little fuel in the middle and burn a new chip and install it into a standard ecu. Cheaper than buying a pfc since I'm not upgrading inj, afm or turbs. Eeprom reader/writer is only $130 and the softwares free! All I need is the map off the mines.
Nice work thou. Its good to see your sussing it out!
Rowdyr32: Yes with my module, a laptop and the right software you will be able to read the Mines map out of the ECU. My display will work with the Mines Chip too..
The best all 'round program is called Nissan Data Scan, and its $25. THe author of this program can be contacted at NissanDataScan@yahoo.com
Impakt
