  • Replies 269
Hi
Due to me upgrading to a PDC, I have one of these for sale ...
obviously its used, but is in excellent condition ..
Came off my R33 GTS-T S2, and worked like an absolute dream !!!
looking for $270 inc shipping ...
Sorry to hijack this thread, but it really is worth owning one of these ...
Please PM me if you're interested
  • 1 month later...
Hi all,
At the moment i have one left which is on the way to the USA, i have ordered some more parts and will have another 20 or so available by the end of the year. Also, if any of you guys dont mind me quoting your responses on the device for another site please let me know!
Impakt
Hi all,
Impakt
Add me to the waiting list, pricing still the same?
Are they compatible with ca18det? My 180's had a manual conversion (in Japan before import) so not sure if ECU was/or needed to be swapped. If you have them for the CA, are manual and auto ECU readouts the same??
If its compatible with a ca18det, will I be able to use just one unit on both the CA and an rb20det? Thanks in advance
THe ca18 ecu doesnt have a consult connector on the loom. I have heard that Consult is supported on the ecu, and that you can wire in your own connector. I havent seen this done with my own eyes though.
Oosh, gtst89, rudager: I'll add you to my list. I should have all parts next week, which means i can start sending them out by the 17th.
Impakt
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
