  • Replies 269
Hi all,
I have received all the parts i need to make another batch today, and will start taking orders. If you would like one, pls contact me with your contact details.
If you would like more info, reply here!
Impakt
Couple more questions, thought this'd be a better spot for it, share the info. and avoid clogging your PM inbox Impakt.
1. What are physical dimensions of the screen?
2. How difficult would it be, for some one with moderate skills, to solder a ribbon cable between the box and screen (say ~30cm length)?
2a. Would the above detrimentally effect the units operation?
The above comes about from the desire to mount the screen in a small space necessitating it's detachment from the box.
3. What's the feasibility of having the display all come up backwards, mirrored, so it could be placed on the dash and used as a Heads-Up-Display?
A switch to choose between Normal/Mirror would be IDEAL!
4. How would, or could, you go about dicking with the speed signal? I ask because i have an auto diff (4.3:1) in a manual car (normally 4.11:1 diff) so my speedo is out, this way i could have an accurate reading.
Good questions Oosh,
1. The physical dimensions of the screen (PCB) is 98mmx60mmx~15mm. THe actual LCD part is smaller.
2. To remotely mount the LCD is not that hard, as long as you know what you are doing. Im happy to sell a display with the LCD and case seperate, so you can mount as you wish. Its 12 wires between the LCD and PCB, so a decent ribbon cable should do the trick. I would recommend you letting me know if you want to remote mount the LCD, that way i wont solder it on in the first place (and create extra work for you).
2a. Won't affect operation at all, just shield the ribbon cable to reduce noise.
3. A super bright VFD or LED module could be used for HUD. LCD will never be bright enough to be used as a HUD.
4. Not possible without re-programming the device, which im happy to do (at a small cost). Just tell me how much you need it tweaked by, and i'll write the code to do it.
Impakt
snip .... /snip
Impakt
Thanks for your answers, if you COULD leave my LCD unattached, i think i will give this a go but please include the wires you would use just in case i decide to go back to stock.
As for speed, it'd need to be altered by a factor of 0.95, i.e. display 95kmh when it's detecting it as 100kmh.
Some further questions:
1. Just how small a fee? :thumbsup:
2. Could i keep the original speed variable? i.e. have a Speed1 and Speed2 var.
3. Will either option (modified or 2 vars) effect compatibility with any of the softwares esp. data loggers?
Cheers.
Found this case at Prime Electronics here in Bridbane.
Did a quick transplant and used some smaller push buttons. Guess I just can't help dicking around with things...
is that a laptop hard drive caddy?
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
