So ever since i got my car back i have two errors
P0021 and P0011
The car got really hard to start , to the point battery almost went flat before it started..
Researching has lead to possible VCT solenoid faults..
Can anyone do me a big favour and get a multi-meter and test the plugs going to the VCT solenoids, what are the volts when on Acc, idle and if possible above 2,000rpm. Mine are 12V the entire time and im sure its only supposed to be 12V at 2000+ rpm... i can unplug both VCT solenoids and no difference to my car running.. rough idle no matter what and has difficulty on cold start. Any help please !
I would say just off that info, that your haltech isn't set up to do the vq35de adjustable cam timing. It's not like the old rb/SR variable cam that is on or off, but actually a table of degrees that the ecu commands at different load and rev situations.
Get the tuner to sort your mapping out, at worst you use the stock ecu to run the cams.
I was supposed to take it into the tuner today, but i cant get it started to get it there!
I will try the stock ecu, the haltech i have is the new ecu replacement one.
Anyone know the section in the Haltech software so i can see if VCT is being controlled ?
Can anyone test their volts for me please ?
More info i have put together on p0011 and p0021 vq35de
The comprehensive component monitor, referred to as the CCM, monitors the Variable Camshaft Timing (VCT) position for over-advanced cam timing. If the cam timing exceeds a maximum calibrated limit or is stuck in an advanced position, the check engine light will come on and set this trouble code.
P0011 is: Intake Cam Position Timing Over Advanced - Bank 1
P0012 is: Variable Camshaft Timing Over Retarded - Bank 1
Possible Causes:
Incorrect camshaft timing
VCT solenoid valve stuck open or continuous oil flow to piston chamber
Camshaft advance mechanism binding, or faulty VCT unit
Symptoms:
These codes usually result in rough idle, stall or hard start.
A P0011 DTC trouble code may be caused by one or more of the following: Incorrect camshaft timing Wiring problems (harness/wiring) in intake timing control valve control solenoid system Continuous oil flow to VCT piston chamber Failed timing valve control solenoid (stuck open)
Things to check
1. 2 seal rings on the back of the cam cover (13035HC)
2. cam position sensors (p0340 and p0345)
3. Clean or replace vct solenoids
4. crank position sensor
5. Low oil
6. Check all fuses
7. Check all grounding esp timing cover x2
8. Check timing chain firing
9. Excessive rtv gasket blocking the oil passages and not getting to the cam gear
10. (ohm meter and they were 7.7-7.8 ohms each), ground and apply 12v to see if they open
11. Check power at the plug (must rev motor to 2k+ for the plugs to have voltage)
12. Check flywheel, if installed just before the errors started has been installed correctly
Related errors
p0300. The VTC solenoid gets energized at 2k+ RPM. This pushes a little piston into a resevior of oil. Through some mechanism, this rotates the intake cams and changes the timing. The piston in my solenoid was getting stuck in the energized position, even when the RPMs dropped and the voltage to the solenoid was not being applied. This means the cam timing was advanced on one bank and not on the other. At this point the ECU and physical cam timing were on different pages, causing a misfire
Edited by R6n350GT
What work was done? Was it at the mechanics?
The hydraulic switch on the cam cover has a small gauze filter on the bottom I seem to remember, this could be blocked I guess. Or one of the actuator pistons may be jammed? I haven't played with the hydraliclly actuated VQ35de as much as the electronically actuated VQ25 cam assemblies but they look similar enough on the camshaft. It seems unusual that you got the car back with the fault...
As the cams run on oil pressure, the viscosity of the oil may play a big part. Any chance it has a thick 20w50 or something in it? That would cause issues in winter I think...
As in whole new engine, turbo put in, engine run in and base tune.
My issues previously was cam had tooth broken off and had cam sensor faults thus me replacing, ecu, clutch/flywheel, all sensors before it was realized it was the cam all along. Now that was fixed i got errors p0021 and p0011 constantly.. Tuner leaned it out top end as my L/100km was 14.7 Hwy driving no boosting! and changed the fuel in the bottom end "cold start up" or something.
So with oil it did it on run in oil (penrite) and now its shell rotella t6 5w40 (used this all the time and never had issues).
From my things to check list
Checked
my passenger side cam sensor is my old one as the new one had a upside down graph when tested so faulty ... i am ordering a new one but i would have code p0350 if it was that.
i cleaned the solenoids with brake cleaner, didnt take the mesh gauze off but sprayed it alot,
Its new and no code
5. Low oil
New oil so its fine
6. Check all fuses
Checked a while ago when chasing my original issues, all fine
Both are on, good connection
Checked
THe mechanics job didnt look messy but none were found in the solenoids
I applied power to them and watched the solenoid open and close - fine
- Mine are at 12V no matter if on Acc, idle or reving past 2000rpm (i would like to see if others are like this..)
Installed correctly
13. Check that the solenoids have a gasket fitted and is in good condition between it and the engine.
- Mine did not have any gaskets, again a screw up by the engine builder
So i think 11. is my issues, possibly 13. but doubt it, new ones are coming either way.
Usually the ecu switches the ground so the solenoid probably does have 12v constant, try shorting the ground side to somewhere on the engine and you should hear it fire.
Any chance you can actuate the cam advance solenoid output from the ecu without the engine running? Does the Haltech allow that in the software?
The hard to start is probably just tuning at a guess, are the new cams aftermarket?
BC Racing stage 2 cams
With hard start i can put stock ecu in and it will fire straight away.
Cam advance solenoid output while engine off, no idea what you mean
Ill try the ground shorting tomorrow. Cheers for the help
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
