yer im heading towards falkens 451's
The wheels i got i cant find any info or pics on them ANYWHERE on the net!!
They are the same ones on the gtr in the link i put on below, except his are white and 18's mine are 17's and silver..
http://www.prestigemotorsport.com.au/au/st...ck/img/1501.jpg
I traked down the ower to find out the model of them as i didnt know.
https://www.sau.com.au/forums/topic/42618-i-need-tyres/#findComment-870823
Just got a set of Toyo Transpath's on my daughters Scooby.
Seemed OK for a "cheap" "performance" tyre.
At $189 fitted for a 215/45-17 seemed a pretty good price as no name brands produced in outer Mongolia go for that sort of money.
Seemed OK in the damp although the daughter's car is not all that powerful.
Got them from Joondalup Tyrepower.
Cheers
https://www.sau.com.au/forums/topic/42618-i-need-tyres/#findComment-877867
thanks for the help guys ill try a few places and see wat happns.. ;)
Oh and my rims arent te85s as the gtr had there called TE-DAY Rims. They look quite similar as those gtr rims but these rims must be pretty rare as ive spent hrs on the internet trying to find some info or a pic of these rims and came up with absolutly nothing!!!
https://www.sau.com.au/forums/topic/42618-i-need-tyres/#findComment-879817
    • So where is this message group so we can organise another meet? Keen to come along and catchup. Might eventually be in a skyline again next year, but the Mustang will have to do for now. Also need to get the WRX back on the road. Stupid f**king money pit that thing is.
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
