Hey guys,
The R33 I just bought has no BOV and as you would expect has your typical no-bov flutter from the air bouncing back and forth. The flutter only occurs when you put a fair bit of load on the engine and it begins to build boost (2800-3000rpm)... Its a GT3582R btw and atm has a pod but am reverting to standard airbox so you cannot always hear it but its still there and would dare say be quieter with the stock airbox.
The big question is, if a cop, 'somehow' were to hear the flutter, could they pull you up and try and get you for an atmo bov (because they probably cannot tell the difference in sounds). If you tried to argue that you do not have one they would probably not believe you etc etc.
Point is, can I technically be defected for this? Has anyone had something like that happen or a similar circumstance. I dont want to have to buy a plumb back BoV just to make it quiet if I dont have too.
Cheers
Its not a loud exaggerated 'dose' like you normally hear its actually really quiet and short with no high pitch lol and doesnt happen if youre just cruising which is good because Im not really into the whole fully hektikkkk dose thing haha.
And yes I am more worried about the huge turbo and will be going to my own measures to make that less sus (probably to no avail).
Could do that angry but its still the whole buying and paying someone to weld it in. It hasnt go any stock piping.
Whack the stock BOV on, pipe it up, then blank it off. Gonna be some effort to fit the stock airbox in with that turbo. I'm gonna assume its got a big intake pipe with a pod on the end. I'd say just make a box out of metal and paint it black. The stock airbox is probably the last concern on any modified skyline drivers mind.
In my old S14, ran no BOV, came out of a round-a-bout one night and shifted gears, cop heard the flutter and pulled me over..
Basically said he heard my BOV, but after explaining it was removed and wasnt running a BOV at all he just left it at that.
Each copper will be different, if they want to defect you, they can and will. Treat them with respect and they may just leave you be.
My 2cents..
No you can't be defected for no BOV. If the cop is a dick he will issue you with a DECC inspection notice and then the inspector will pick out all your defects.
You can. Technically, being part of the inlet tract, it is part of the emissions system and is therefore verboten to alter.
Technically you are correct however a cop won't defect you for a BOV if he cannot see it.
Both times I have had my car DECC inspected I was told by the inspector "Remove your BOV because the people at the EPA don't like seeing them"
That comment alone tells me the pen pushers there are inconsistent in their rulings.
in summary, you can be defected for any modification (removal, addition, change) to the intake / turbocharger system
regardless of what or why
its simply a matter of if the relevant authority notices the modification (removal, addition or change)
I have been defected for an aftermarket ECU, copper couldn't see it.
Basically the police will defect you if the believe its modifies/not original. Then you have to prove it to whoever is clearing the defect.
I'd say nope, not defectable. When my 33 first went over the pits 5 years ago when I didn't know any different, first thing they spotted was my atmo BOV. Got told to block it off, so I replaced it with a blanking plug and they gave the all clear.
  • 1 month later...
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
