Hey guys,
The R33 I just bought has no BOV and as you would expect has your typical no-bov flutter from the air bouncing back and forth. The flutter only occurs when you put a fair bit of load on the engine and it begins to build boost (2800-3000rpm)... Its a GT3582R btw and atm has a pod but am reverting to standard airbox so you cannot always hear it but its still there and would dare say be quieter with the stock airbox.
The big question is, if a cop, 'somehow' were to hear the flutter, could they pull you up and try and get you for an atmo bov (because they probably cannot tell the difference in sounds). If you tried to argue that you do not have one they would probably not believe you etc etc.
Point is, can I technically be defected for this? Has anyone had something like that happen or a similar circumstance. I dont want to have to buy a plumb back BoV just to make it quiet if I dont have too.
Cheers
Its not a loud exaggerated 'dose' like you normally hear its actually really quiet and short with no high pitch lol and doesnt happen if youre just cruising which is good because Im not really into the whole fully hektikkkk dose thing haha.
And yes I am more worried about the huge turbo and will be going to my own measures to make that less sus (probably to no avail).
Could do that angry but its still the whole buying and paying someone to weld it in. It hasnt go any stock piping.
Whack the stock BOV on, pipe it up, then blank it off. Gonna be some effort to fit the stock airbox in with that turbo. I'm gonna assume its got a big intake pipe with a pod on the end. I'd say just make a box out of metal and paint it black. The stock airbox is probably the last concern on any modified skyline drivers mind.
In my old S14, ran no BOV, came out of a round-a-bout one night and shifted gears, cop heard the flutter and pulled me over..
Basically said he heard my BOV, but after explaining it was removed and wasnt running a BOV at all he just left it at that.
Each copper will be different, if they want to defect you, they can and will. Treat them with respect and they may just leave you be.
My 2cents..
No you can't be defected for no BOV. If the cop is a dick he will issue you with a DECC inspection notice and then the inspector will pick out all your defects.
You can. Technically, being part of the inlet tract, it is part of the emissions system and is therefore verboten to alter.
Technically you are correct however a cop won't defect you for a BOV if he cannot see it.
Both times I have had my car DECC inspected I was told by the inspector "Remove your BOV because the people at the EPA don't like seeing them"
That comment alone tells me the pen pushers there are inconsistent in their rulings.
in summary, you can be defected for any modification (removal, addition, change) to the intake / turbocharger system
regardless of what or why
its simply a matter of if the relevant authority notices the modification (removal, addition or change)
I have been defected for an aftermarket ECU, copper couldn't see it.
Basically the police will defect you if the believe its modifies/not original. Then you have to prove it to whoever is clearing the defect.
I'd say nope, not defectable. When my 33 first went over the pits 5 years ago when I didn't know any different, first thing they spotted was my atmo BOV. Got told to block it off, so I replaced it with a blanking plug and they gave the all clear.
  • 1 month later...
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
