I guy on these forums contacted me as I was looking for a bonnet for a stagea said he one but was interstate.
I sorted everything out with him price and postage. Then direct deposited the money and now the guy has vanished. Kept saying he was busy he will get to it. Now wont answer my calls won't respond to msgs. Added him on Facebook contacted him that way. Then he deleted me.
The guy on here's name is TANGENTS.
I have his full name and address but don't think it's right. To disclose that just yet.
All I want is the bonnet or my cash back.
https://www.sau.com.au/forums/topic/426201-dont-trust-tangents/
where in nsw, if he is close to me i will kindly knock on his door for you :domokun:
Please tell me you plan on making him pay up with q little stick just like that emocon.
On another note sux to hear about people ripping people off on here, but as said above im sure some nsw members would be willing to do a house call
Administrators please pull this down if further action is needed I am happy to go to the appropriate people but I will let this stand another couple of weeks. out of benefit of the doubt. Cheers for everyone's offers. Just thought people should know.
Internet forums contain the full spectrum of people; it's inevitable that bad things will happen, and it's naive to think that everyone is trustworthy.
Given this was resolved with a successful outcome; perhaps it would be an idea to edit the title of this thread, or even lock it; so that it doesn't keep arriving at the top of the page with a negative spin on Tangents trustworthiness.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
