For the past year this has been my absolute pride and joy. I've spent over $20,000 on getting this car to where it is now. Car is currently registered until December but will not be supplied with a rwc. Chassis has done 193,000kms. I got it at 190,000kms with signs of wear so i put a new low k motor in it. Bought off smmotorsports. New motor was fitted with a cometic steal head gasket. Arp head studs.
Bolt ons: Hks 3037 turbo. External 38mm tial waste gate with screaer pipe. Stainless hi mount manifold. Steal braided oil and water lines. 3" turbo back exhaust with magnaflow muffler. Modified standard inlet manifold. (Forward facing) Xf 80mm throttle body. Aluminum top feed fuel rail. Bosch 750 injectors. 2lt surge tank. 044 fuel pump. Apexi power fc computer with hand controler. Gtr front mount intercooler. Front mount oil cooler with steel braided lines. Remote oil filter. USA #1 hi flow oil filter. Reusable. Hks twin plate clutch. New plates fitted. Kaaz 2 way diff. Just Serviced and still like brand new. Hicas lock bar. Comes with 370z 17" wheels with fresh rubber. Rolled guards. Tein coil overs. Adjustable caster arms ans top control arms. Has a full 6 point weld in bond roll bars roll cage with side intrusion. Rear seats removed. air con and heater box removed. stereo removed. Deep dish steering wheel with hub kit. Hydraulic hand brake installed aswell as the cable hand brake. Does not come with the seat in the picture. comes with a standard gtst driver seat. I'm sure theirs more but I can't remember. I didn't plan on ever selling the car which is why I poured so much money into it. Unfortunately things have changed. My loss your gain.
The car was dyno tuned and set up by sam markov (smmotorsports) Makes 344.1rwkw on a very safe 15.8psi. Only done 1500km on this current set up. Car runs on power plus e85 fuel. Always used lube alloy oil. Redline shock proff oil in the gearbox. As mentioned this will not come with a rwc or the hot996 plates. Car could do with fresh paint. Unsure how the cage will go passing road worthy.
$10,500firm. inbox for email or phone number. located in wangaratta.
https://www.sau.com.au/forums/topic/426212-r33-s1-gtst-3441rwkw-10500/
  • 1 month later...
