  • 5 weeks later...
I'm going to add a vote for iron chef imports because I'm completely happy with the car I received from them.
There were no hidden surprises except for the bonus it has some nice coilovers that I was unaware of.
The quality of the paint and car in general is exactly as described.
If I import again then I will be going through them. Thanks guys
  • Like 1
  • 3 weeks later...
Another vote for the team at Iron Chef Imports. I got my Crown Estate through them, they were quick to reply to any queries I had, kept me well informed and were very professional to deal with.
Another vote for iron chef
They just imported my r33 and I have nothing but good things to say about kristian and troy :)
Couldn't be happier with the car and it was well within budget.
I'm currently half way through the process on importing a V35 Skyline using Ben from J-Spec Imports.
You can check out my blog about the whole process if you're interested and read up on my thoughts about both J-Spec (Import Agent) and Bespoke (Compliance Workshop).
www.v35skyline.com :)
4 cars I had imported through Nsp. 3 out of 4 cars were fantastic while the only 1 was average
So a 75% hit rate is not bad.
R34 Gtt sedan - great
Evo Tme - fantastic
R34 Gtr V Spec bayside blue - average
M35 Stagea - excellent
Very happy with my S30z & the service I got through Craig at Diyimport (kakimoto33 on the forums)
Quick to reply to my questions & kept me informed every step of the way. Highly Recommended!
http://www.diyimport.com.au/
https://www.facebook.com/diyimport
Ive bought 3 cars of Phil AKA PRIMO on here or Direct Imported Japan, each one was a great car. I can’t recommend him highly enough and he would be the only one I would buy from for future cars. He has been around for a long time.
Edited by 33SOM
  • 4 weeks later...
I would like to add another one for Iron Chef Imports. I hope it will count.
For full disclosure, I did not get to the stage of having a car landed and complied (reason below) however I did go through every other process involved. Searching for a car etc. I have to say Troy was brilliant, nothing was to much trouble and I sure bugged him a heck of a lot. The process was very easy all my concerns were met and I felt completely secure during it all.
The reason I did not get one landed, was because in the end I decided I wanted a new model vehicle and because of import laws (car now sold in Australia, I couldn't import) I ended up buying a 2014 Australian car, NOT a import.
I bought my NM35 off the lot at JLM. Great service by Todd and his team.
However, I'd give ICI a plug too as I had an email conversation over a few weeks with Kristian about preferred models before deciding on the NM35. I was leaning towards a Legnum over the C34 and Aristo until the NM35 reared it's head after a successful test drive with Adam at JLM.
Does this count for both?
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
