Arrived couple days ago from brad profab for our dry sump set up. Also Bc picked up a pump elsewhere which saved us heaps of cash, Brett and dean have heaps of contacts in the Motorsport industry so we are lucky or else this new build would honestly not be possible.
Now some new aero and spray job required, so off to Andrew Kinsmore, Kinzy paint and panel to attach our new side skirts, spray up the interior and engine bay. Decided to match it all in same colour. Our old n1 side skirts I thought looked awesome, always loved them but to much air was getting under the car and causing lift, so added these which dropped the 220mm front and 240mm rear gap down to 100mm, open class allows ride hight at 65mm, we can perhaps lower it a little more, there will be a full flat floor after time attack which will get the hight down.
Mate that thing is a rig 470kw is leathal on the track you aiming for more power with precision turbo?
Our weakest link will be the block I believe, 450-500 should be fine for time attack, if we run 470 plus for a lap or 2 then we will pull the engine apart for a refresh after the event. The biggest advantage over the new engine turbo set up is when the power delivery will kick in and the higher rev range, as prior we didn't exceed 8200 I believe from memory.
Fitting up the front canards. Wool tuff test to see how the air flowed around the skirts, and to position the canards correctly. If only I had another 100k to spend on aero...then we could try pro class. I really appreciate when I see teams going flat out with aero as it makes a huge difference, but running pro class these days comes down to cash.
One of many tests performed at Bc automotive.
www.youtube.com/watch?v=Hi3Ym22ruog
Our new goal lap time for Phillip Island is 1.31, we believe this will equate to around 1.29-1.30 at Sydney Motorsport. Going by the Gt series cars and deans experience there's about 2 seconds difference in the track if set up correctly. I will post more as work progresses, if you would like to follow the build on Facebook or through Bc automotive the links are below. The build will be complete by July 7th latest to get back for more testing at the island.
Hope the links work,
https://www.facebook.com/BCAUTO
http://www.bcautomotive.com.au/
Good to see it coming along.
The touring car guys used that wool test in years gone by as well.
The interesting part when fitting up the side skirts in front of the rear tyre the air would stall(wool tuft would just fall), so we pulled the side skirts out just a little in line with the wheel and it would flow perfect without the tufts stalling. So we will fit it up like this and painted by Tuesday. Thanks heaps for your work on the oil pan, speedy return and great work.
Excited.
Any idea how many Victorian cars are competing? Congrats on club class dude, will be a fun few days. I've noticed Wtac aren't posting all competitors as most cars aren't ready yet, and they are building up the hype.
While I'm waiting for the painting, thought I'd share some other work that has been carried out by dean and Brett over the years.
Ap racing front and rear brakes, with brake bias adjustment. These were a massive step up in stopping performance from the csc brakes in the past. Also repositioned the oil cooler to the side vent which solved the engine oil temp getting hot after even 2 laps in the past.
Dean made up an aircraft aluminium stainless steel side exhaust which you can pick up with 2 fingers. Eliminating the old full length exhaust saving around 12 kg. Needs to be modified to fit through the new side skirts.
Exhaust looks awesome, sorry I must be confused with the material.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
    • A 180SX has a much better look than a FD. The roofline is far superior being a fastback. It's popups look better. In a world where we all subconsciously add a little bit of low, and wheels of our preference, it's just more handsome than the FD is. The FD just looks 'bubbly' in comparison. It can come down to preference, sure. But "The FD is the BEST looking (on appearances alone) 90's JDM car without question?" Nah. Plenty of questions lol. I could think of 8 cars I think look fundamentally better, and probably a handful of ones that look about on par with a FD. (like say a SW20 MR2) I feel people like/overrate the FD because of it's mythicality/rarity, its rotary and it's unpredictable nature. It probably drives great, you can stuff a ton of tyre under there, has a unique sound, light as hell. I feel that people reading this thinking "YOU CANT RATE A 180 ABOVE A FD BECAUSE A 180 IS A CHEAP DRIFT BUCKET" prove the point about bias as to what the car represents, moreso than how it actually looks.. I feel the 80's boxy/squared off look is becoming better looking due to time, and 90's melted soap bar aesthetics have not aged well. (yet?) And this thread is purely about looks :p
    • A red or yellow S15 wins my vote, Ack that it just scraps in with the 90's cars theme, but they are great looking little sports car Next would be a A80 Supra (pre face lift), whilst the A80 has its own issues, I feel is the best looking larger GT car As for the FD, "I" feel that the reason it triggers me in a non-positve way when looking at one, is like looking at a high maintenance pretty girl who you know is mentally unstable and likely to explode for no apparent reason
