Also removed the aeromotions computer which weighted 3kg, that is heavy. So in total another 4kg out of the car for the day. We have bets on what the car will weigh once completed, Brett and I reckon 1270kg, dean reckons 1250 and if its not he's gonna cut everything out till he's right. Next week ill start on the bonnet and chop it up.
The whole engine except for the hypertune plenum was cryogenically frozen, from the block to the clutch and flywheel, head, nuts and bolts, the lot. I have no idea if this actually prolongs the life of the parts, but went for it on the engine builders recommendations.
I have heard good things about the cryogen. I didnt think it was worth it personally, but apparently it does make a difference. Got told they put some valves in a vat and they were noticeably harder to machine afterwards.
Did you buy a unfinished camshafts and have them custom machined? how much did that work cost (minus the camshafts themselves)?
I hope so, I guess time will tell.
Nah, they are an off the shelf order. My engine builder is secret squirrel when it comes to the cams. Not sure why, they are just cams I say. But I wanted to at least show everyone the specs of em. Edited by stevena
+1 for wrapping.
You'd get wicked glare from the sun if you dont.
Wouldn't be fun half way through a turn and the reflective light from the sun blinds you!!!
Great ideas guys, I even had to look up "flocking" as I didn't know what the process was, have seen it before but didn't know what it was called. I like the dark carbon look wrap, not sure if Steve's is black or carbon black, bit hard to see with that photo but love your dash dude.
Carbon doors with plastic windows weighing 8kg, I can't decide if I should cut up the door also, I can get another 1.5-2.5kg out of them, cut or leave?
Cut em. This is balls out, every little bit counts.
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
