re-drill top mounts to copy nismo
and slap r33 lower arms which ar 10mm longer
thats how the "dirty non cheating targa spec cars" do it
I was under the impression the R33 GTR LCAs didn't fit?!? or were different mounting? Otherwise I'll do that straight away :)
I would support Russell's comments on these upper suspension arms as they are a good piece of kit.
When the top arm moves through the suspension travel range the top arm attempts to twist which it cannot normally do and instead it chops out you top arm bushes. This design has a pivot point in the middle of the arm which allows rotation reducing friction and saving your bushes from damage.
To test this if you take the spring out of your front coil over and push the suspension up through the travel range you will feel the friction as the suspension attempts to twist the top arm. With these UAS arms in place the suspension movement has this friction removed because the top arm can twist on the pivot point as it moves up through the suspension travel range.
I leave all the suspension stuff to dean as it goes over my head. But I did ask him bout what you guys advised and he said it has been checked and all is good. In regards to camber etc I don't know how its set up as I trust what is done by the guys, but if more was required I'm sure without doubt they will advise we need it. Cheers guys,
Massive days in lead up to phillip island. Car was started Sunday early morning for the first time, and I got to hear it today.....it sounds tuff and lumpy on idle, awesome, completely differently to the old car set up.
Everyone was working on it today, dash attached, body loom was and still is being made and will be finished tonight. Body loom weighed 2-3kg which was a guess by hand.
post-19978-0-33494400-1378722051_thumb.jpgpost-19978-0-67796100-1378722081_thumb.jpgpost-19978-0-68478100-1378722267_thumb.jpg
  • Like 1
Unbelievable.... Car was tuned by dean, and phil armour who flew down for the day. Massive thanks phil. This engine is a monster. Posting a crappy phone quality of it on the dyno, unfortunately I can't post any graphs or mention power in respect to the team as time attack is just around the corner. But what I will say is this new engine doesn't even compare to the old engine, like night and day.
Car sounds and looks great Steven!
Have you sort out your front suspension yet?
I've a full set of front Ikeya arms at Riverside if you need it. Believe it or not, that is my second set that I have installed in that car to roll around and dyno only lol The Ikeya arms have not seen the street or track!
First set went to a mate because my car was getting work and he needed it for the track. Now I won't need this front setup because Riverside made me a custom front set. I will need the rear until Riverside has time to do the rear setup. I think I also have the Whiteline sway bar made for dry sump....depending your dry sump pump.
It's there if you need it ....otherwise I will float it on the market when I have time after WTAC.
Thanks dahn, all good with suspension buddy. I also have a brand new set of ikeya sitting in its box we have never needed to use as yet. But appreciate the thought. Speak to freddy... We have a transporter that can fit 2 more cars in, if your interested fill me in.
So first test session at phillip island didn't happen and lucky for 2 reason. At 8.30 last night just prior to loading car on the trailer the boys noticed an abnormality with the engine so played it safe, engine out this morning and all is well, few days set back. And reason 2 is we heard it was a wash out at phillip island.
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
