Been thinking and discussing with a friend what price you could you possible get for my fully caged shell if I was to sell it all in parts stripped?
Also anyone want to take a guess what I could sell the whole motor for?
Now were only discussing this so not sure what will happen as yet. But some realistic guesses would be great.
shell maybe 3-4k and might take a while, depending on what sweeteners you add with it.
motor maybe 15-18k could also take a bit and as above depends what extras are on it. i forget what you actually have in terms of internals and all the like.
i've stripped a few before but never really sold a shell, usually fill it with scrap metal and get about 400-500
at the end of the day your always going to make more in parts than complete.
Car is no longer for sale, I couldn't part with it. I was selling cheap Because funds were going into another gtr32 to compete in pro class this year. So if I can raise 63400 that should see this beast hit pro class, with the aim of a 1.23 lap time. I know it can be done I just have to raise the funds some how. Another fun year ahead lol.
  • Like 1
Yeah 63k ish should be enough to get the lap times downs on top of this car already. That means full floor with more aero, more power, and new suspension. But raising that money will be difficult so not planning on doing any time attack events yet, I just want to get into it and drive it sometime next month. Maybe a winton day or wrx Calder next month. Will see.
  • Like 1
  • 3 weeks later...
This is true, picked up the car from vpw in epping which we had on display. car stolen between roughly 1pm and 6.30pm, on an open tandem trailer ready to be transported back to bc automotive from my place in essendon. Trailer was locked secure. Middle of the day, someone had to have seen something or know something, we've had a report already in regards to a trailer spotted at an address and cops are on it. If anyone hears anything please contact the police, if anyone notices second hand parts for sale please check the serial numbers on em prior to purchase. Thanks
  • 1 month later...
Since the monster isn't competing I can show one of the power graphs prior to the event at wtac. At world time attack it was turned up even more but I don't have that graph as it was on phil armours dyno. I could ask, but this should give you an indication of what was going on.
  • Like 1
I should also mention the reason the graph drops off around 7500 is from wheel spin. Rev limit was 8800. Even with 3 fat people in the boot couldn't stop it from spinning on Brett's dyno. I'll try and get phill's dyno graphs.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
