Also removed the aeromotions computer which weighted 3kg, that is heavy. So in total another 4kg out of the car for the day. We have bets on what the car will weigh once completed, Brett and I reckon 1270kg, dean reckons 1250 and if its not he's gonna cut everything out till he's right. Next week ill start on the bonnet and chop it up.
The whole engine except for the hypertune plenum was cryogenically frozen, from the block to the clutch and flywheel, head, nuts and bolts, the lot. I have no idea if this actually prolongs the life of the parts, but went for it on the engine builders recommendations.
I have heard good things about the cryogen. I didnt think it was worth it personally, but apparently it does make a difference. Got told they put some valves in a vat and they were noticeably harder to machine afterwards.
Did you buy a unfinished camshafts and have them custom machined? how much did that work cost (minus the camshafts themselves)?
I hope so, I guess time will tell.
Nah, they are an off the shelf order. My engine builder is secret squirrel when it comes to the cams. Not sure why, they are just cams I say. But I wanted to at least show everyone the specs of em. Edited by stevena
+1 for wrapping.
You'd get wicked glare from the sun if you dont.
Wouldn't be fun half way through a turn and the reflective light from the sun blinds you!!!
Great ideas guys, I even had to look up "flocking" as I didn't know what the process was, have seen it before but didn't know what it was called. I like the dark carbon look wrap, not sure if Steve's is black or carbon black, bit hard to see with that photo but love your dash dude.
Carbon doors with plastic windows weighing 8kg, I can't decide if I should cut up the door also, I can get another 1.5-2.5kg out of them, cut or leave?
Cut em. This is balls out, every little bit counts.
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
