Guest Munky
Just thought I'd post a few questions that have popped into my head in recent days.
Firstly
1.) What type of petrol should I use for my N/A? Premium? Optimax? Normal Unleaded? (in case it's not in the FAQ)
2.) What's the stock sound system like in R34's? All mine has so far is a CD stacker. I'm wondering if I'll just need to add an amp, a headunit and subs, or whether I'll also have to install new speakers.
3.) What do you look for when looking for wheels for your car? I hear alot of people asking about Offset etc. but have no idea what that's about. I wanna get 17 or 18's for my R34 at the end of the year, preferably in a style similar to P1 Buddy II's (Gunmetal or White). I don't know which rims are compatible tho!
4.) Where can I get dials for the middle dash like R34 GTT's have? My car has nothing above the airconditioner, but I'd like a few dials there! Is it easy to get the same type as in GTT's or would it be better to buy some from a third party company. Also are those dials even necessary? From pictures I've seen, I thought those dials told you things such as your oil levels, so I'm wondering where my oil levels will be displayed?
Please answer as many as possible :)
Cheers guys!
https://www.sau.com.au/forums/topic/42624-a-few-questions/
Your oil pressure is on the speedo...to fit the GTt cluster you need to do a bit of messing around as we've got a moulded dash, where the GTts have a cut-out in that position.
BTW those dials aren't really necessary for N/A as one of them is a boost gauge, mainly just there for wank factor.
Stock sound system is not that great...get an amp, sub and splits to start with.
Use the best fuel you can afford, I wouldn't recommend anything less than premium!
https://www.sau.com.au/forums/topic/42624-a-few-questions/#findComment-872148
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
