So, I've been chasing a HICAS issue off and on for a few weeks, and I am having no luck. I have an R32 GTS-4, but I'm using a GTR manual for wiring and I don't think they are similar at all. I was wondering if anyone has either a GTS-4 or GTS-T manual for download or that you can send me. I have checked every link on all of the main Skyline websites, and had no luck. Either the links are to a GTR manual (which I already have) or they are dead links from 10 years ago.
I also tried to do the self diagnostic, and it doesn't work. I'm leaning towards a steering angle sensor for that issue, and my speedometer for HICAS/power steering getting heavy while driving since it's completely incorrect (it's not in MPH or KPH). But like I said, the wiring isn't the same and I can't accurately shoot the steering angle sensor for voltages to check if it's bad.
https://www.sau.com.au/forums/topic/426241-r32-workshop-manuals/
My R33 had a similiar problem hicas light on,no power steering,found there was a couple of leaking capacitors in the hicas computer,had them replaced by the local tv repair man,problem fixed.
Well, right now it's a possible toss-up as to the solution to my problem. I'm getting very strange readings for the steering angle sensor, so I'm sort of leaning towards that considering I'm also unable to enter diagnostic mode (the remedy for which I've heard is VERY likely to be steering angle sensor related). It could also be the speedometer as it's reading incorrectly, but I don't know. I just wanted to see how different the wiring is between the two, because I've heard (and also seen first hand) that the GTS-4 and GTS-T use the same HICAS system, while the GTR had "Super HICAS".
I'm just trying to ensure I'm shooting the correct wires before I start ordering more useless parts and wasting my money. I've already ordered a speed sensor only to find out it didn't help at all.
Jiffo, I'm not looking at 4WD, I'm looking at HICAS which are two completely different systems. 4WD is the engine power going to all four tires, HICAS is four wheel steering. I know I'm fairly new to the Skyline, but I'm not a complete idiot considering I read wiring diagrams and shoot wires every day for my job (using PDF files, ironically).
Right now, I'm thinking it's 75% chance of steering angle sensor and 25% speed inputs being jacked up. I want to make sure it's 100% of one and 0% the other.
Appreciate that, but if you look at the wiring diagram mentioned, it shows the HICAS computer and wiring, all on the same diagram.
when i got my gtst the hicas light was on constantly
fixed by taking the steering wheel off and lining up the dot on the inside of the wheel with the one on the column (werent aligned before) when i reconnected the battery no more constant hicas light!
Jiffo, besides the fact that those diagrams were scanned horribly, it still doesn't show me pins on the steering angle sensor. Again, they are different in the other diagrams I've used from the GTR manual than on my car. Besides the fact that in the diagrams it shows eight pins (mine has 6, which I cannot be for sure, but maybe those were airbag wires or something), I've confirmed two of the wires are switched from the GTR manual to my car. From what I've gathered, the GTS-T and GTS-4 used a slightly different HICAS system than the GTR. This is why I want to acquire one of the other manuals to be sure. Considering the strange readings I've been getting, I think the wiring is different. It's just a way of being redundant and making sure everything is right before I waste more money chasing problems that might not actually exist.
Hicas light comes on maybe five minutes after I start driving, which is also when the power steering gets heavy. It's almost the exact same place every day. It's one reason I originally thought the speedometer. The strange thing is I don't remember having this problem when I got it, and the speed has always been wrong. So now I'm leaning towards steering angle sensor, considering I can't enter diagnostic mode, and I'm getting such strange readings. Again, I'm just trying to be redundant and verify before wasting time and money on nonexistent problems.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
