So, I've been chasing a HICAS issue off and on for a few weeks, and I am having no luck. I have an R32 GTS-4, but I'm using a GTR manual for wiring and I don't think they are similar at all. I was wondering if anyone has either a GTS-4 or GTS-T manual for download or that you can send me. I have checked every link on all of the main Skyline websites, and had no luck. Either the links are to a GTR manual (which I already have) or they are dead links from 10 years ago.
I also tried to do the self diagnostic, and it doesn't work. I'm leaning towards a steering angle sensor for that issue, and my speedometer for HICAS/power steering getting heavy while driving since it's completely incorrect (it's not in MPH or KPH). But like I said, the wiring isn't the same and I can't accurately shoot the steering angle sensor for voltages to check if it's bad.
https://www.sau.com.au/forums/topic/426241-r32-workshop-manuals/
My R33 had a similiar problem hicas light on,no power steering,found there was a couple of leaking capacitors in the hicas computer,had them replaced by the local tv repair man,problem fixed.
Well, right now it's a possible toss-up as to the solution to my problem. I'm getting very strange readings for the steering angle sensor, so I'm sort of leaning towards that considering I'm also unable to enter diagnostic mode (the remedy for which I've heard is VERY likely to be steering angle sensor related). It could also be the speedometer as it's reading incorrectly, but I don't know. I just wanted to see how different the wiring is between the two, because I've heard (and also seen first hand) that the GTS-4 and GTS-T use the same HICAS system, while the GTR had "Super HICAS".
I'm just trying to ensure I'm shooting the correct wires before I start ordering more useless parts and wasting my money. I've already ordered a speed sensor only to find out it didn't help at all.
Jiffo, I'm not looking at 4WD, I'm looking at HICAS which are two completely different systems. 4WD is the engine power going to all four tires, HICAS is four wheel steering. I know I'm fairly new to the Skyline, but I'm not a complete idiot considering I read wiring diagrams and shoot wires every day for my job (using PDF files, ironically).
Right now, I'm thinking it's 75% chance of steering angle sensor and 25% speed inputs being jacked up. I want to make sure it's 100% of one and 0% the other.
Appreciate that, but if you look at the wiring diagram mentioned, it shows the HICAS computer and wiring, all on the same diagram.
when i got my gtst the hicas light was on constantly
fixed by taking the steering wheel off and lining up the dot on the inside of the wheel with the one on the column (werent aligned before) when i reconnected the battery no more constant hicas light!
Jiffo, besides the fact that those diagrams were scanned horribly, it still doesn't show me pins on the steering angle sensor. Again, they are different in the other diagrams I've used from the GTR manual than on my car. Besides the fact that in the diagrams it shows eight pins (mine has 6, which I cannot be for sure, but maybe those were airbag wires or something), I've confirmed two of the wires are switched from the GTR manual to my car. From what I've gathered, the GTS-T and GTS-4 used a slightly different HICAS system than the GTR. This is why I want to acquire one of the other manuals to be sure. Considering the strange readings I've been getting, I think the wiring is different. It's just a way of being redundant and making sure everything is right before I waste more money chasing problems that might not actually exist.
Hicas light comes on maybe five minutes after I start driving, which is also when the power steering gets heavy. It's almost the exact same place every day. It's one reason I originally thought the speedometer. The strange thing is I don't remember having this problem when I got it, and the speed has always been wrong. So now I'm leaning towards steering angle sensor, considering I can't enter diagnostic mode, and I'm getting such strange readings. Again, I'm just trying to be redundant and verify before wasting time and money on nonexistent problems.
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
    • Your off site links didn't work for me, and in any case it is easier for forum members if you post the pic directly either as an attachment or a link so the information is all in one place. That aside, the sills are the correct place to lift the car, whether with the factory jack or a hoist. Yes you should use rubber blocks with a slit for the seam on a hoist to avoid bending the pinch weld (where yours is currently bent, just bend it back if possible eg vicegrips), and be aware of the height you need in the blocks to clear any sill extensions to the hoist arms as it lifts If what you are doing needs access to the sills, the rear subframe bush would also be strong and secure. I'm not sure what you mean by sidemember (maybe same part I mean by sills) but be careful that your front support point is not too far back as the car is very front heavy and could overbalance.
    • Here's my first iteration - white duct tape so color is off, but this is just a straight line across the bonnet lip. From a geometry standpoint, this is probably closest to what a GTR has. Next up is some $5 white pearl vinyl and some rubber door sill trim, applied to the BACK of the bonnet lip. It's more accurate placement to the GTR, but also follows the body lines on this setup a bit more. Couple more pics on this config incoming: Again, a $5 vinyl and rubber job, it's  POC still and not how I'm gonna run this part. But one thing I'll note is that the black trim does need to "straighten out" a bit, and instead of going completely along the line of the bonnet lip, might be better suited to wrap over the "horns" of the bonnet lip, giving it a less aggressive curve up at the ends.  The correct way to do this would be to paint it body-matched and then decide how you want to make the black line. If you used paint or a pinstripe, you could have the black line go straight to the corner of the headlight where the rubber strip typically meets the headlight on a GTR.   Hope this helps!
