Parts are located in Springwood (20 mins west of Penrith) Prices are negotiable so make a reasonable offer. Prefer pickup but can post/courier at buyers expense. Lots more parts to be put up so keep an eye on this thread for updates. Here's what I have so far. All parts are from my R32/34 which was up for sale in an old topic. Have most receipts for items. Heaps of stock and aftermarket parts in near new or excellent condition. Be quick. Need this stuff gone ASAP!
CONTACT Luke BY PM OR ON 0429 098 883
post-23286-0-80330800-1359437359_thumb.j
Lenso GT05's 19x9 (front) 19x9.5 (rear) with about 90% tread (235 fronts and rears) Mint Condition $1450
post-23286-0-54087500-1359437377_thumb.j
Custom manifold with turbosmart ext pro gate (can seperate) $799
post-23286-0-29863300-1359437390_thumb.j
FMIC with custom alloy piping, hoses, clamps included $499
post-23286-0-24605000-1359437401_thumb.j
Near new BMC enclosed pod filter unit $199
post-23286-0-15463700-1359437421_thumb.j
Near new 50mm core radiator $199
post-23286-0-83915900-1359437461_thumb.j
Greddy catch can with hoses $119
post-23286-0-63564800-1359437468_thumb.j
Turbosmart sleeper series supersonic BOV with plumpback attatchment $219
post-23286-0-78419300-1359437595_thumb.j
6 x Siemens 630cc injectors with fuel rail $799 (can seperate)
post-23286-0-64366600-1359437503_thumb.j
R34 Neo intake manifold $149
post-23286-0-28066200-1359437513_thumb.j
R34 Neo stock plenum $75
post-23286-0-86703800-1359437561_thumb.j
Air con compressor with hoses etc $119
post-23286-0-60047900-1359437568_thumb.j
R34 Neo alternator $75
post-23286-0-45031700-1359437575_thumb.j
R32 gtst power steering setup $75
post-23286-0-98522400-1359437579_thumb.j
Mint R32 GTR front bar with N1 slots, Custom blue $499
post-23286-0-45409300-1359437589_thumb.j
Splitfires with wiring etc to suit RB25 $450
post-23286-0-79725200-1359437601_thumb.j
Ceramic coated down pipe $80
post-23286-0-50721000-1359437607_thumb.j
R32 GTR front reo bar $149
post-23286-0-68654100-1359437714_thumb.j
High quality car alarm with paging system still in box $119
post-23286-0-05366400-1359437719_thumb.j
Boss kit to suit R32 $40
post-23286-0-58374300-1359437739_thumb.j
R32 GTR fuel pump $80
post-23286-0-46722300-1359437744_thumb.j
Chrome guage cups with all brackets $15 each
post-23286-0-51429800-1359437749_thumb.j
Stock R34 Neo injectors $119
post-23286-0-97470400-1359437753_thumb.j
4 x Stock R32 gtst rims 16" need new tires $199
post-23286-0-21264200-1359437760_thumb.j
Genuine R32 GTR front bar mesh $50
post-23286-0-18462600-1359437765_thumb.j
R34 Neo throttle body $75
post-23286-0-73641000-1359437769_thumb.j
Custom 3.5" turboback exhaust system, ceramic coated, resonator, hiflow cat, big chrome cannon, ext wastegate piping, under 90dbs $799
https://www.sau.com.au/forums/topic/426257-r32r34-parts-for-sale/
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
