a bit of fishing line and some 'bug/tar remover' to get rid of the adhesive and you should be fine.
Personally I don't like the debadged look, it makes me think 'dodgy backyard repair job', but each to their own. Certainly better than having badges in the wrong spots as I have seen on some cars.
I had my badges taken off when i had my boot resprayed from a scratch. At first i liked the debadged look but i kinda want the badges on again.
Problem is, im pretty anal about getting the badges back in the right spot and straight. There doesnt seem to be any information in regards to the exact positioning of the badges :ermm:
If you're going to remove the Skyline badge you may as well get rid of the 350GT i don't think the nissan badge and the 350gt badge without the skyline would look good at all. I prefer my car debadged front and rear, only because these are rare cars and not many people know what they are.
I have heard that if you de-bdage the big nissan badge on the boot, it leaves a mark?? Like a outline of the badge....
can anyone confirm this?
Depends on what color the car is, i have personally seen those outlines you talking about but it was on a Red v35 (very prone to fading) but other colors might be a different story.
doesn't bug/tar remover get rid of that residue? when i bought my car the previous owner looked like he literally attacked the rear nissan badge with a screw driver and left a long/deep scratch where it was.. got the boot resprayed the painted removed the other badges for me.
This is how mine looks, dirty with a boot lip too.
This is after a detail, since removing the skyline badging reveals slight indentations where the lettering used to be.
I used fishing line and bug and tar remover that was in a green spray bottle but never again because it slightly stained the paint, another reason why I had the car detailed.
Edited by Triggs
  • Like 1
I'm not talking about the glue residue, what I'm talking about is the slight indents the "NISSAN" badge will leave after removal.........
does anyone else have this issue after they debadged???
You can't really see it in the photo...so I guess a cut and polish helped you remove the indentations?
does it really leave 'indentations'? or is it just an outline because that part of the paint hasn't seen the sun over the last 10 years?
I wouldn't have thought Nissan would 'indent' the panel for the badges?
I definitely think it looks much cleaner without the skyline wording attached to the boot.
I will attempt to give it ago on a v36.
Anyone done one on a v36?
My V36 is debadged, both the nissan and skyline badges are gone.
Got mine off with a heat gun on very low to warm up the glue, then rubbing in small circles with a white cloth and some eucalyptus oil. (I stress white cloth as I used a green microfiber first and it actually transferred color into the paint - had to cut n polish it out with some pretty aggressive compound).
    • You would probably do a lot better in a claims process then most people. When I called the insurance company, they were surprised I read the pds because according to them almost no one does lol.
    • Yeah it should be, but I wouldn't be surprised if the insurance company tries to pull some argument out of their ass to avoid paying you out.
    • On some cars like MR2 Turbos they're notorious for not letting the wastegate open far enough to avoid overboost, especially certain cheap downpipes. If adjusting "percentage cycle" fixes it then it's just an electronic control issue, not a hardware one.
    • Same.  It's depressing to say this but the skyline can go months on the charger between drives.
    • I often leave mine connected weeks at a time. The main one I use is the old model of this, it has 2 important features - choose battery chemistry other than lead acid (most of mine are AGM) - power supply mode which you can use to try and recover dead flat batteries as "smart" chargers often don't recognise a dead flat battery is connected https://www.projecta.com.au/products/IC10/intellicharge-10a-bat-chgr The Ctek I  use was meant to have a battery test mode as well but it doesn't work 100% of the time so I am pissed at them. The distributor did everything possible to make warranty and support difficult so I'll stay away in future. The main thing with a "trickle" charger is it has multi stage programs, ie once the battery is full it turns the current right down to just maintain the charge....in the old days we just used real "trickle" chargers for that which had a maximum output of say 500mA which was safe to just leave connected to dumb old lead batteries.
