How To Adjust R33 Gtr Front Head Lights
Hi guys, I've been getting high beamed by many people on the road with some saying that my lights are pointing too high up and need to be adjusted down more as my head lights are glaring people in the eye.
I have HID's but they are only the 4,700k ones I think so not super bright but just want to adjust my head lights to point down more. Does anyone know how to do this?
Some pictures and instructions would be much appreciated.
Cheers
Kevin
I have HID's
That's why they're flashing you. Having "4,700K" lights (colour of the light) has nothing to do with it's brightness. You can try pointing your headlights down as much as you can (so you don't see much ahead of you), but it'll still cause glare.
There are 8mm headed rods at the back of the headlight to adjust it. If it doesn't move, it's most likely either at end of thread (turn it the other way).
 Share
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
    • Oh for sure, I'm just recounting my thoughts 😎 I'm not what you've got there to fuzt with.... likely my first idea was on the money -- rebuild or replace connectors. You can get a lot of connector stuff here  -> https://www.rapidcables.com.au/ Didn't look in the boot of mine, because I replaced these when I renewed the pump (plastic of connectors had gone brittle) edit: what I used... https://www.efihardware.com/products/2120/Deutsch-DTM-Connector-Kit-6-Pin ...cheaper... https://www.ebay.com.au/itm/364900039138
    • In no way was i suggesting it’s your fault mate. The trailer cable has a plug that I removed. I will have a closer look, but I did remove the trailer wiring cable with the tow ball as I don’t need it on my silo. i have replaced the fuel pump already there’s no need to remove the cradle again I can see the wire colours from it in.
