I have the complete kits including a brand new unused thermo switch since i used ECU fan controller.
The electric fans have been used for about 2 months in total and are in brand new condition.
2x
http://www.daviescraig.com.au/Thermatic_Fans-DCSL12_INCH_FAN_KIT__12_VOLT___PART_No__0062-details.aspx
1x
http://www.daviescraig.com.au/Controller___Switches-MECHANICAL_THERMAL_SWITCH__12V___24V____PART_No__0401-details.aspx
Plus relays and wiring so you can bolt this straight onto your car.
The new cost just for the fans and thermo switch is $360 plus cost of the dual relays and wiring.
Im after $250ono for the lot, Pickup in Sydney would be ideal.
    • A super responsive 250 would be nice in a daily.
    • My son saw this Porsche 904 in Yodoyabashi in Osaka, not sure if it's the plastic or fibreglass version 767605763.559358.mp4
    • I agree re not trusting it as it makes mistakes however can do hours of research for you at times by simply asking a question
    • The I've done a lot of research and feel like I'm becoming a nut and washer expert. The washer in question doesn’t look very conical—it’s almost flat, but one side has a chamfer. The guide's picture shows the convex side (chamfered side) facing the nut, but the text says the chamfer should face the pulley, which is confusing. If I follow the picture, the chamfer faces the nut, but the instructions say the opposite. When I place the washer on a flat surface, one side looks flatter—maybe that's the concave side—so I would expect the chamfer to be on that side. But it isn’t, which adds to the confusion. The term chamfer is also throwing me off. I always thought the concave side should face the pulley, and the convex side (with the chamfer) should face the nut or bolt head. But Nissan’s instructions say the chamfer should face the pulley, which seems backward. I know I’m probably overthinking it, but I want to be sure I’m doing it right. Also, I’ve seen some people replace the nut and stud with a bolt, but I assume that’s not a good idea, since it might not keep proper tension on the tensioner. Lastly, just to be 100% sure: the pressure washer should face the pulley, then the conical washer? That feels strange, since usually the pressure washer goes first, facing the bolt or nut.
