OK i dont know much about engines so i will try and explain this to you guys.
I was changing my plugs the other day and when I took the big metal pipe that crosses over where the plugs are in, there was a small amount of oil in the pipe and I am pretty damn sure there shouldnt be.
Do you know what this is from and how bad is it.
https://www.sau.com.au/forums/topic/42634-what-could-this-be-from/
Sounds like excessive crankcase ventilation.
I understand it as follows - as you wind in more boost or your rings become worn pressure from the combustion process will pass the rings and enter the crankcase. From here the excess pressure breathes from the rocker covers into the induction piping (or in extreme cases from your dipstick hole). Most will get caught in the intercooler but some will make it the plenum. If its only a small amount it should be fine but installing a catch can between the rocker cover vent and the induction piping will prevent most oil from i) entering the combustion process which can cause detonation ii) clogging your cooler and restricting flow. Its an indication your motor is becoming tired but i've also seen tight motors breath heavy if you dial in enough boost.
Worst case scenario would be broken ringlands and/or rings.
Yeh its nothing ben,
Awhile ago when i was running 12psi most of the time it was getting a bit of oil in the throttle body, now that its on standard boost, i havent seen any oil in the last 2 spark plug changes.
Im jus getting a catch can, easiest way to combat it.
i have something related to this in my rb25 silvia i recently bought, the oil is in the intercooler piping from turbo to intercooler (maybe other side, not sure).
from reading this im guessing oil on the engine side of intercooler isnt too bad, but turbo side (unless it came from engine?) is worse?
    • Thanks for your insight, it being basically useless will impact my decision for sure. I thought it may help the engine breath better I guess. But then again, I have also been told that tuning an RB20DE is also not worth it. Exactly, we follow EU Regulations. There is a bit more leeway on older vehicles. My Porsche 924 came without a cat from factory and managed to pass, they still mentioned that I have quite high emissions on it though.
    • My apologies, I stand corrected. Thanks for registering to mention this! And thank you for actually reaching out to the council to clarify. This is the sensible thing to do and the opposite of what I was alluding you were doing. I may have seen too much outrage and hate being fueled on the internet and it has made me a somewhat cynical old man. Sometimes it is easy to forget that there are real people behind websites and accounts. In my defence, CarExpert and CarExplore do read quite similarly at a glance. I shall try and do better in the future. (Please stick around to get the latest scoops on dealing with old Nissan shitboxes )
    • Don't bother. The poor little RB20 doesn't make enough gas flow to challenge the flow capabilities of even the littlest cat, and you won't make any extra power, and all you'll do it soot up your rear bumper. Plus....is Malta not runing under Euro regs?
    • Hey Daniel, sorry to hear that and thanks for posting up for us at a really hard time I only knew SmoothLine through the forums, we never met as we are based in different states, but when he was most active on here he was quite a while back so not many of the current crowd might remember him. I am pretty sure he was active in the Queensland SQU club but that is defunct now too (times are changing and we are all getting older). Farewell SmoothLine!
    • Turns out depending on whether the car was equipped with TCS or not there are different signals coming to the dash, meaning there are different speedo clusters.  Wired in a speedo calibrator box from aliexpress and now works fine.
