He was joking. It wont work on stock ecu and wont gain you anything anyway. They measure air flow and your engine will not be flowing anywhere near enough to need a Z32
No the RB30 head will flow about 300HP, more than the standard AFM can take.
https://www.sau.com.au/forums/topic/426349-z32-afm-on-rb25/#findComment-6878045
oh ok lol. so no differance at all ? what about accuracy/ reliability ? if theres such thing ?
tl;dr - you will waste your money on a Z32 AFM + computer/nistune + tune. It is only required if your engine is maxing out the AFM (turbocharged engines running bigger turbo)
https://www.sau.com.au/forums/topic/426349-z32-afm-on-rb25/#findComment-6878184
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
