For those that remember the gold mid/late 90's 3.0L V6 Magna (rego: BOOYA) from the 4, 6 and Rotary Nationals... it looks like he decided to get serious! He was on the SA part of our forum for a short while too.
  • Replies 66
looks like the photos were taken here at Wayville Showgrounds, with the Truckworks tow truck in the background of one pics, and a GTS Monaro with SA plates in another pic. Wasn't there a Street Machine show or something the other week at Wayville? Methinks he was down here for that. He is from Alice Springs fyi, and seemed like a nice enough bloke to talk to, but got mighty defensive (as I would too) when some of us bagged him on the forums for having a Magna :D
By the 'looks' of the modifications this thing has big hp potential! It's got a pretty big turbo, huge FMIC, serious fuel system (custom rail and just look at the hardware in the boot!) it even has a custom plenum. If the internals have been upgraded then it would be very interesting to see just how much grunt this engine makes? A turbocharged 3.0L V6 would have a bucketload of torque too.
Yeah, big HP and FWD are a scary combination.
Remember Nightcrawler test driving a hotted up turbo cordia many moons ago, me in the passenger seat, and this thing hitting boost and swapping lanes on us in the blink of an eye!
Never again I said.
yes that was certainly one of the scaries moments I have had in a car ..... luckily we were on MacIntyre Road and there was a lane to spare, otherwise we'd have been toast. I obviously didn't buy it after that experience.
hey i saw that car here quite a while ago ... he used to have a huuuuge wing ... LOL i guess all the baggin on this forum made him take it off ... but how much would all those mods cost to do?? and only 240fwhp .... thats like 180fwkw ... hardly seems worth it??
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
