  • Replies 66
yeah, 250kw ATW with the turbo and stock internals
he's hoping for 500 or something HP with better internals
ran 15.3 at AIR with the 198HP (not sure whether at engine or not) NA build
After looking at the dyno sheet, it appears to me that it made (on the previous engine: stock internals, injectors + bolt-on turbo) 249.9fwkw running dangerously lean!!! >14:1 A/FR is lean for an atmo engine, let alone one with forced induction!
With his new engine and turbo set-up I'd say it "should" have big potential. After all we are talking about a very close match for the Mitsubishi 3000GT engine. With his 3.0L V6 now sporting stronger internals and serious support systems to match it will be interesting to see how it goes on the dyno at Autosalon.
I dunno' about the bit on his web site about leaving "burning Skylines and WRXs on the side of the drag strip"
wow tough crowd here.
At least this bloke is putting in some effort for performance not rice.
And in the end fwd is no issue when you're in Alice Springs, its not like there's a heap of standing starts or corners to contend with :)
In the real world (i.e no complete combustion or 100% efficient use of fuel) 14.7 AFR at the top end of an engines rev range is not healthy, be it NA or forced induction. The NA LS1 Commodore guys would be a tad worried if they were getting 14:1+ AFRs! Have a look at the BOONGA Magna dyno sheet, post turbo upgrade. Those top end AFRs look like piston munchers to me.
hence why i didnt we didnt do more then 13psi. and i did write on the dynosheet "max injector flow"... we didnt just strap a turbo on and say "its good enough"
we found a faulty earth to the pumps, which in the end killed both bosch motorsport 700hp pumps.. :Bang: ... which *may* of had a negetive effect on the final HP figure, as the computer was asking for more fuel, the pump just couldnt supply because of bad power system to it... i will only find out once i replace the pumps :rofl:
so not happy there.
im currently building the new engine with bascally every internal component replaced. aiming for 400fwkw. dyno and stip only.
on the street, the 250kw i already have is a killer!!!.. my 19's just smoke up when i lauch too hard :throwup: ... still have to refin my lauch style
Cheers for the comments :headspin:
Ben.
www.booyamotorsport.com
No matter how much everyone bags you out, I think its an awesome car. Got looks and sounds as if it would go like stink as well. All the Skyline boys saying how its shit coz its a FWD and not giving it a chance probably think that they are the quickest car around with the only mod on their car being a cat back exhaust and pod filter. Me thinks it would leave many Skylines for dead, if it gets good traction to the ground!
.....All the Skyline boys saying how its shit coz its a FWD and not giving it a chance probably think that they are the quickest car around with the only mod on their car being a cat back exhaust and pod filter.  .....
:):):D:):D:rofl::rofl::rofl::rofl:
does this mean you only have a cat back?:)
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
