Seeing if I can sell my KE70 Toyota corolla.
Colour - Cream
Mods are -
Extractors w/ full through 2.5 inch exhaust
5sp manual gearbox (originally 4sp)
Cd Player/AUX (NO speakers)
XYZ racing coilovers (adjustable dampening)
Front and rear custom sway bars
New poly bushes (only front replaced)
Comes with 4 stock wheels/tyres (wheels in poor condition)
+ 4 after market rims with tyres (80% tred)
All new spark plugs/leads
Carby taken apart and cleaned
Still runs fine!!
The Bads -
Pretty rusty, NONE in chassis only shell
Slight whining noise coming from diff
Think the clutch is on its last legs but has not slipped yet..
NO rego or RWC
Pick up, goldcoast. $1700 o.n.o. OR swaps!
Reason I've got it up for $1700 is because that's what I payed for all the suspension work done.
Contact me for pictures or more info. On 0406624953
Edited by Zrobe
https://www.sau.com.au/forums/topic/426390-ke70-4-door-manual/
- See more at: http://s580.photobucket.com/user/Zrobe91/media/image-8.jpg.html#sthash.DsHldZ7E.dpuf
- See more at: http://s580.photobucket.com/user/Zrobe91/media/image-9.jpg.html#sthash.UULwH720.dpuf
That's all I have on my phone ATM.
I can take some more this afternoon.
Edited by Zrobe
Bump if this car isn't sold before the 27th of July, I'm taking coilovers/sway bars/wheels/MP3 out and selling separately.
And taking shell to wreckers... :(
Edited by Zrobe
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
