Had the oznats over the weekend...
The car wasnt finished but just bolted it together... need to finish the interior and the front end , side skirts etc etc
Have to sort out my traction issues. Even with slicks i cant keep the power down. If you listen to the video im constantly on and off throttle and constantly loosing traction. even on the well prepped drag strip. any ideas would be great
video-1477097823.mp4
  • 7 months later...
On 25/08/2015 at 11:21 AM, Adz2332 said:
Long time coming but i got the car tuned, again. This time by a different tuner and to say it was tuned badly seems an understatement.
Havent had a chance to take it out to the drags again but have a drift prac day coming up in 3 weeks i think, so will test it out then
attached the new dyno print out
Who did the good tune ?
On 28/04/2014 at 0:51 PM, Adz2332 said:
stripping down the engine at the moment. removing things i dont need and getting it ready for.....
This.....
HTA3076R
also have a trial waste gate, dump, 6boost mani and screamer
10307394_10154088892755215_2184393771918
I wanted an FP HTA turbo before i got mucked around and sent a wrong turbo.  Nice to see it made plenty of power
  • 4 weeks later...
Put on some AR1s  285s all round and went and did a track day at mallala on sat.
was a blast. car went really well and the tyres were excellent for the price
i now need to upgrade the brakes as it boiled its guts out and lost all braking by the end. and also get some coilovers to
But was a great day!
  • 3 weeks later...
forgot to add.
had the VCT sorted working and tuned before the track day. You could see a bit of a difference on the dyno print out. but the butt dyno it made a hell of a difference. felt boost came on so much earlier and smoother. made the car so much easier to drive and so much quicker all round.
Funny how much it changed the whole feeling of the car
  • Like 1
  • 1 month later...
currently getting parts together for a rb25/30 build.
so far have a 30 block
my rb25 head, 6boost main, plazaman plenum, 1000cc injectors, computer etc etc
have to work out, pistons, bearings, rods etc
want to go big to hold 450kws ish...
any links or builds i should look at?
No, but we did one earlier this year so I've got a fairly good handle on what's needed. We used a stock bottom end (found an RB30 bottom end that had never been run).
It's the little things that you'll need to sort out:
- the oil feed for the VCT (the machine shop we use has done quite a few 25/30's & knows what's needed),
-what you do with the cold start crap and associated hoses (we removed pretty much all of it, and don't regret it),
-coolant lines on the intake side (once again we got rid of some),
-the oil drain / breather on the front exhaust side (RB30 block doesn't have the port for this),
-engine mounts / raising the bonnet (we kept the mounts stock, and raised the rear of the bonnet with some spacers under the hinges - also had to ditch the strut tower brace. Didn't want to lower the mounts as we have an extended sump, and didn't want it to be the lowest part of the car),
-the dump pipe (had to cut & extend ours, as turbo was now 40mm higher),
-you'll probably need a new RB30 water pump (the RB25 one has a slotted hole, which doesn't quite cover the water channel in the block - ask me how I know),
-the intake piping (once again because the top of our engine was higher, we needed longer intake pipe silicone joiners on the intake pipes, just above the exhaust manifold. Had to buy a 1 metre length as we couldn't find the right size in smaller lengths),
-you will need to buy a second timing belt tensioner & a longer timing belt
-intake side wiring - we had to make up some extended loom mounts because the head was now higher.
I can't think of anything else at the moment. If you want the machine shop's contact details let me know - he's in Pooraka. We are loving the engine - the torque delivery is beautiful.
looking at some budget coils.
Monopro Type Coilovers- Street/Track
http://www.option1garage.com.au/HSD.htm
or
http://www.option1garage.com.au/BCRacing.htm
BR Series Street and Circuit Coilover
  • 1 month later...
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
