  • 3 months later...
  • 4 months later...
Just a quickie update
Finally the sound deadner is all out and is looking a lot neater!
The bulk was easy to get out with the dry ice but the little bits were a pain in the ass
10647018_10154623509795215_1000552000041
10561566_10154623509890215_8980687063001
Bought some rims for when i do drags, just a test fit
10372580_10154633723710215_1766731431429
10614158_10154633723790215_9187005122008
Cheers guys
Picked it up for not alot when you take into account what i sold off of it as it was very neat!
if / when i come to selling it ill most probably strip. Havent spent a whole heap, as most things ive done myself and also got second hand on here.
More of a budget build then anything else
Will upload a bunch more pics in the coming weeks and specs as it will be up and about for mallanats in adelaide, in a months time! heres to giving some V8s a suprise!
  • 3 weeks later...
Few more pics of the progress
Gets a tune wed so will post results to
Interier almost done.
Slicks fitted on the rear and front runners with spacers up front.
G4+ link computer in
just needs a tidy up now, but the bulk is done
  • Like 2
Just looked back over the thread, I had in my head this engine had upgraded internals but looking back over I can't see any evidence of that - is this a fully stock block?
STOCK STOCK block. Stock head just new head gasket and studs.
Have another engine im slowly buying parts for to forge eventually. Just seeing how long it will last before it goes *pop*
Thanks guys will post results as soon as i get them
If you have a decent tuner you will find it will be a long time before it goes pop! I still have the stock headgasket too remember lol
hahah i have taken inspiration from your set up and efforts! defiantly subscribed to your build.
hoping it lasts 12 or so months and give me time to get parts for a build together... plus i keep chopping and changing what i want to do / go about it
Lol now i might have to do the same with your car, time to get dry ice and some weight reduction happening lol
hahah
The dry ice works really well. i got around 10 kilo of it but could have used more. defiantly the more you can afford the easier the job becomes!
Trying to find a carbon boot and looking at lexan rear 1/4 windows and rear window.
    • @robbo_rb180 I already have a NEO head on the shitbox 馃槑 Just needs beehive springs so I can rev it past the 8600 rpm limiter, then again pointless too, turbo is out of puff lol. Wen da gods let me win lotto eh?
    • Everyone I know with a90 supra at time attack aren't having issues with 3-5 fast laps so far and one is decent powered one too. Saw a k24 swapped 86 with a 8hp70 and big slicks and aero which had no drama's at QR and Manton Park. I've stuck a 25 row cooler in my setup with 8hp45/50 in the hopes of keeping the oil cool as I plan on some racing next year that 20-30min sessions. I've also geared my car so won't be using 7th and 8th gear too. @Dose Pipe Sutututu just needs to get that samsonas in already and have that tassie guy fit a head and rev it too 11ty thousand rpm.
    • My embedded systems thoughts have me sitting with GTS on this. Variation between same phone hardware, should be small. However, the internal "intensity" or "volume" amount that say Google passes to the app, will be quite different, as the underlying hardware will be passing different levels for the same volume to the Google OS. Until the app creator has had each individual phone, and set benchmarks and calibrations for each, the amount of error can be quite huge.   It can even be observed by using different phones, recording the same noise, and then playing it back, they end up soon ding different. A big reason for it, is even the different types of mics used in phones have different responses, and different frequency ranges. Then you need to get into the DSP, and the variations in those, their sample rates which then effect their frequency range, and then the quality of the DSP, and what type of hardware conversion they do to for the ADC within the DSP. Oh, and let's not forget at the low level phones are designed to cutout loud sounds. It's one of the reasons they suck in really loud environments (eg concerts). The louder you yell, the more you'll get cutout too Note DSP is Digital Signal Processor ADC is the analogue to data converter. I don't have any real data on what the variation would truly be, however, chat GPT says in general, their output is typically between +/-2dB to +/-5dB of what you're really measuring. So realistically, anything from 4 to 10dB variation is possible even with the same devices.
    • 'sif the error will be that low!
    • I do know where there is a fair few 馃槈
