Hey all,
Since I bought the car this light was not lighting up. Then, out of no where, it started working. Now its stopped. Ive fiddled around and can't seem to find what is stopping it from working. Anybody else have this light not working? Is it a simple system to diagnose? I'm assuming its just a switch in the seatbelt buckle connected to the dash. No time to pull apart the seat now but always good to see if this is a common fault with a common solution.
I would assume that the seatbelt buckle has 2 contacts on either side, and when the seatbelt clicks in it completes the circuit. Because the light has been off mostly, I would assume it might have shorted to ground somewhere before the seatbelt buckle.
This is if my assumption about how the circuit works is correct.
Otherwise the seatbelt may push a switch down inside the buckle which would be a normally closed circuit in which case you would be looking for a broken wire pre or post switch
Pull the plug under the seat and check both wires (I''m pretty sure its a 2 pin plug) With the car on, one should have power and no ground, the other should have ground and no power.
If its a 1 pin plug then it should have power at the wire and no ground and it must ground through the buckle and seat rail so check there is a good earth from the seat buckle bolt/nut to a good chassis earth
This is all assumptions remember, Hopefully helps. Good place to start anyway, as the plug is easy enough to get to and you dont have to pull things apart
Awesome guys cheers for the input. I'll pull out the seat tomorrow and have a look around. The problem is definitely under the seat. Wasn't working today so I stuck my hands under had a fiddle around and it worked then went out again. Does the passenger seat have an input or only driver?
only driver, There would need to be a weight sensor in the passanger seat for it to work otherwise the seatbelt light would always be on. There is a plug for it under the seat but dont think it plugs in anywhere
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
