<p>Ive never been on here and looking for advice for engine mods for my r33 gtst just spent $4000 on exterior that ill never see again but anyway time to pour some cash into the engine.
i was thinking is it a better idea just to put a rb26 in it seriously and go from there.
Edited by casper33
Want to keep the auto so when i go for a drive and decide to get on the beers the mrs can drive me back
It defiantly feels like i am going fast
But the way that ford man handled me
Put me right back in my place
For the cost of buying and fitting a rb26 you could build a 25 with a buttload more power.
And to try and keep up with the Ford, do exhaust, intercooler, wind the boost up to start with.
  • Like 1
  • 1 year later...
i ask this coz im spending $1300 on a new ECU with a nistune chip and it puts out 176kw at the rear wheels now. only have intercooler upgrade and spitfire coil packs
Oh dear you are gonna have to spend quite a few Bob to see em off ,on the track of coarse
I spent 10 grand 9 years ago best money I ever spent,she still go in strong after all these years,also my
daily do 30000 plus a year what fun. :-)
I spent 10 grand and have three boost settings my liner is set for safe and reliable driving
do some reading on mods in here you will find every thing you need to know.
Enjoy your skyline they are a fun fantastic drive every day I open the shed door those hot plate rear lights
make me smile just as they have for 12 years. :-)
  • 3 weeks later...
If you wanna make big power theres nothing surprising about throwing $30,000 to $40,000 at it. The guy who runs the performance workshop around the corner from my work is building a '33 GTR that is expected to make 500rwkw and so far he has given him $30k with at least another $10k expected. RB26DETT, twin HKS turbos, three throttle bodies for laminar air flow, insane amount of engine protection, computer will retard engine with even slightest change in oil pressure or temp spikes... Too much to list.
This thing makes me want to cry simply because I don't own it.
But if you want to make good power, highflow the turbo, intercooler, exhaust, coilpack upgrades, nistune, and maybe bigger injectors....
Should get out of that for around $5-$6k.
*My advice...
A '33 GTST makes around 170kw from standard, which is plenty fast specially if its your daily. Buy another one, turn it into a racecar and save it for the track. No need for stupid horsepower running around on the roads.
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
