What Is 'too Much' Power For The Street?
74 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
My 26 GTS4 with 280 odd kw is more then enough on the street - to the point were i haven't even touched the high boost setting
Mind you its running RWD at current so i take it half easy - and is the first Forced Induction car i have driven so of course it feels quick to me
The power im getting used to it....
Hard question to answer but id say even 200kw is more then enough
my gtr had 280rwkw, wasnt anywhere near enough.
all of it was usable on the street.
and I did at times.
well, overtaking anyway.
Varies - but I would say when the driver thinks it's a pain (pig) to drive in traffic. -> unrelated to kws/power <-
driver, clutch, gear box, gear ratio's, steering, suspension/set-up, brakes, tyres
but to provide some general indication due to the subject 100 to 400. (so I spose that's saying I think over 400 :wacko: )
Depending on the driver, vehicle and the destinations frequently travelled.
Edited by Sinista32
I reckon 300kw's is enough for the street, at street speeds its all about the low down torque, to me a VL turbo is/was the ultimate streeter, 3L's of good low down torque off the line with just the sound of the rb whistling thru the streets , riding the clutch for spool ups or frying second gear up a short stretch
^^ This is how Canberra is starting to look...
But as people are saying it's all down to the driver there is no such thing as too much power for the street.
I always thought 350kw would be "enough" but it wasn't and as I go higher in power level I still drive mine on street on a regular basis when I have it.
I can name four 1000hp Supra's running manual boxes that could be driven daily.
And a few V8's making 1000hp+ on the street with manuals.
Commodore going around with twins on it making 1200 rwhp, and he drives it everywhere no problem.
That being said, a turbo'd V8 has more low end than a Supra or Skyline.
AWD cars aren't usually modded to big power limits because A: More to Break.
And B: Name an AWD car other than a Lambo, or GTR that is capable of producing 1000hp. (Very few I'd assume).
The reason most 1000whp cars are RWD is because 99% of sports cars ARE Rear wheel drive.
Just throwing it out there.
But 500hp is plenty for street bragging rights.
And upwards of 1000 hp is a bit ridiculous, only if you go to the drags every week is it worth it, other wise it's mostly a wank factor IMO.
I'll just be happy cruising in a 280awkw GTR...
LOL.
Too scared to break it. :-\
Too much power is when it puts you into a pole before you can react.
No, that is being irresponsible on the street! Nothing to do with power... With some of the drivers on the road these days i am sure there are people in camper vans capable of this!
A twin turbo commy would be pretty awesome, and unique mainly.
But, a GT-T is a RWD, so that would be better to run 1000hp then a GTR AWD?
Also, i could imagine modifying a GT-T to a twin turbo would be excellent fun, said no one ever.-.-
:blink:
Why would you want a twin turbo GT-T? Well in that case it would be a GT-TT lol...... In saying that it has been done more than once on this forum and was no advantage over the single!
I think this thread has been full of opinions and personal beliefs on a question that is really not going to get a correct answer.
DO your research and learn what cars can and cant do, the 1000hp number gets thrown around a lot but very few will ever get there in a street car as there is no point! That and the fact that to do it Legally is impossible as far as i am aware!
Twin turbo commy would just make a shitty car, expensive!
  • Like 1
:rofl:
Its not easy for a 2.5 6 pot either...
34geteetee makes 391rwkw on 28PSI, whereas not only is Scotty's stagea running 4PSI more, but makes 50rwkw less despite running the equivalent turbo and displacement (2.5 6 pot)
Sometimes its not about displacement or cylinders, but more so engine design, the RB2.5 motor is certainly capable of huge numbers with head work and a built motor, but once again irrelevant for street use
I don't have a built motor or head work? Actually I don't even have an aftermarket headgasket so u fail to see how they contribute to big numbers?
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 馃槢
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
