Hi
32 GTR Boot lid with N1 carbon lip, genuine spoiler and badges in blue $285
32 GTR door glass rare with no scratches or tint. $140 each
32 GTR Door left and right Blue plus right one in Black. $175 each
32 GTR & GTST drivers side control panel for windows, mirrors, $90
drivers side Relay $65 motor $80
32 GTR side mirrors Black $45 each includes wiring
32 GTR tail light in black or white $45 each
32 GTR rear bar in Black $150
32 GTR rear reo $120
Reverse lights $85
Number plate lights $35
OS Giken 32 twin plate push-clutch over 90% new with no launches $1000 over 2k new
Pickup Brisbane or I can box up for courier quote go to www.e-go.com.au
Regards Taylor 0408188777
  • 2 months later...
Won't let me send you a PM? I get an error message.
Reckon you could send/upload some pics of the 32 GTR mirrors on here or to me on 0406624953
Cheers.
Edited by Zrobe
Hi Guys
I have just cleared some space in my mail box,
Reverse lights are still available
I just need to check on the mirrors
Yell out if there is anything else.
Cheers
  • Like 1
  • 5 months later...
Happy New Year
I was holding some of the parts for a few people but they didn't come thru. everything still available
All the best
  • 3 months later...
Update
Wing on boot is sold.
Boot with Carbon N1 lip, Gtr badge and Nissan badge for $185
OS Giken twin plate Clutch includes flywheel and bearings. Great condition.
  • 3 weeks later...
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
