hey all im new here my names jake im looking for advice on a weekender im thinking of buying, im from sydney and the car im looking at buying is from vic. Here is the ad
http://www.carsales.com.au/private/details/Nissan-Skyline-1996/SSE-AD-2040323/?Cr=2
im just worried ill get defected on the way back to syd for all the mods, any opinions would be great its my first gtr as I can finally afford it.
any opinions good or bad will be appreciated thanjs all
Awesome looking car! Your first concern should be, CAN you get it through a blue slip as is? If not, how much will you have to change and spend to get it through?
When making a purchase like this make sure you have cash spare for these sort of issues!
The car looks really well built BUT NSW rules of late have been so strict and are being enforced, so if there are any potential defects on the car in NSW then work out what to do about it before it happens...
I would say the car may be known by the SAU VIC guys, try ask them?
But REVS check, EPA check and speak to a Blue Slip station!
Looks like it needs more boost
Why do you say that? Doesnt seem to be helping the OP on his purchase decision?
Yeah thats exactly wat I was worried about. Any ideas on how I could check if it would pass a blue slip without having the car in nsw? Another problem is its only registered untill the 10th of this month so if I wana drive it back I need to move fast and get these checks done. Im really hoping I can buy this car and yeah I got spare money after purchase as I was kind of expecting these probs with interstate car deals. U guys think its worth the risk?
Blue slip requires an inspection - ie you need the car in NSW. You will need to read up on the rules as to what will comply and what won't - looking at the engine bay and the list of mods - there are alot of things that will have to be reverted back to stock to pass.
Yeah the boost does seem to be running quiet high??? 21psi at the street tune seened like akot to me but im no exoert.
for the power levels they would be 2860-5 turbos - 21psi is quite normal for them.
Oh bummer4 that was my main concern a few things is fine but alot of things is not so good Im thinking its a bit too risky for my liking such a shame cause im in love with this car
there doesn't seem too much under the hood that would make an issue... Remove the catch can, replace the airbox, unbolt all the shiny accessories and the coil pack cover. the rest is just bling
Edited by polishstorm
Im really stumped on wat to do atm, im contemplating just buying it lol as long as its not gonna cost me over 5k including rego n on road costs ill be happy. another concern is the seats can they defect me on those as well?
plus the ecu, boost controller, exhaust etc.
Most of the parts you need, you should be able to borrow off people - It's just the labour time that will be costy - unless you can do it yourself.
Edited by wedge_r34gtr
Seats will be fine
I was just exaggerating as this thing is a machine
easiest thing to do is source a good blueslipper that doesnt have to look at the car ;)
yeah thats the obvious option lol...but if you need to ask, you generally dont know someone that will do that for you
Well guys I took the risks and decided to buy. Its well worth the risk and travel as soon as I saw it, its by far the cleanest gtr r33 I seen the attention to detail is amazing. Hopeing to get it registered early this week.
Good luck with it mate. I hope you find a good blue slip place to take it to.
If you take it to a place and they say they need you to spend thousands of dollars in order to get it back to close to stock for the blue slip get them to make a list of exactly what needs to be changed and post back here. Don't let them start working on it.
Edited by *LOACH*
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
