a interesting read that RB25 heads flow abit more up top but with more lift then the RB26 RB25
- STD valve size
- 100% cnc ported
Valve lift .100' .200' .300' .400' .450' .500' .550' Intake CFM 91 172 228 261 272 281 286 Exhaust CFM 76 136 176 188 192 194 196
RB26
- Accepts s.t.d. or oversize valves
- 100% fully c.n.c. ported
Valve lift
.100”
.200”
.300”
.400”
.435”
Intake c.f.m.
97
179
247
280
285
E xhaust c.f.m
83
146
173
188
192
    • Holy hell! That is absolutely stunning! Great work!!!
