Hey guys, struggling to find some infomation about putting 3.5 or there abouts diff ratios in my GTR diff. So story goes I have a R32 GTR rear diff in my 180sx with a 2 speed glide with a KAZZ 2 way diff center fitted. It currently has 4.11 stock gearingit and im wanting to put around the 3.5/3.6 in it. I have access to a R34 GTR V-SPEC active LSD diff which is 3.5 ratio. Now my question is will the crown wheel and pinion from that fit into my R32 GTR diff? Or any other infomation about going to a lower diff ratio would be MUCH appreciated
Thanks.
https://www.sau.com.au/forums/topic/426467-changing-gtr-rear-diff-ratios/
ahh good question....not sure.
I do know the 34gtr front diff gears do not fit in the 33/34 casing/sump, but I am not sure about the rear.
Can you get the diff casing as well as the centre?
You sure about that Duncan? You have written 34GTR front diff doesn't fit in the 33/34 casing - surely it will fit in the 34 casing? I have an R34GTR front diff waiting to go in my R33 sump and have just been looking out for an R34 non V spec rear diff to go with it - I know some R34 GTRs over here have put R33 diffs front and rear to lower the gearing so I have always assumed that the reverse was possible.
I think there is a good chance it won't fit. The Nismo GT-Pro diff price list expressly says that their diffs do not suit the active LSD types. That would suggest to me that there is a lack of commonality between the pumpkins and the CW&P sets.
People who have swapped non-active diffs into V-specs have generally put the whole diff in, case and all, yeah?
It would seem obvious to me that if the OP has access to the V-spec diff, that he should obtain it, take it apart and see if the CW&P will bolt to another R200 centre (surely there's one lying around that you can access). If it will do that, then it will fit your diff too. Oh, unless there's also some difference in nose length or whatever that might also cause trouble, but you should also be able to check into that upon dismantling the diffs.
  • Like 1
You know, there are so many wrong things in my post that maybe I should stop drinking and typing. The correct statement is:
r32/r33 ratios (4.4 and 4.1) will not fit in the r34 front diff casing (3.5).
I know you've said it has been done, but they must have either modified the casing or used the 32/33 casing/sump (they bolt on the block fine). The 32/33 crown wheel/centre is too large for the 34 casing.
Correct :)
Although it's more then point that Nismo do not make a GT Pro to fit a Vspec A-LSD... So it requires a swap out with a non-Vspec.
At least that's with a R33.
Correct :)
I just did this conversion two weeks ago. I also needed shafts AND my V spec bolt pattern did not line up with the flanges that Nismo supploed in the kit. Both were a 6 bolt pattern but not the same size.
How sure are you on this? I bought a brand new R34 GTR sump/diff and was going to fit my crown wheel and pinion and lsd centre from my R32 GTR front diff into it.
I had no idea that the casings were different between models
Yep that is exactly what I tried. The casings are different.
I have just done a search and the part numbers for R32 and R34 GTR front sump/diff casings are the same (3842003V00).
I might give fitting it a go and I'll report back with how it goes
Please do report what you find - I have a diff swap planned and would like to know how you get on!
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
    • You need to buy a Saab Matt, ours had a button that turned all the dash lights off. Any decent aftermarket dash has sufficient brightness control and a headlight input for day/night settings. None of which probably helps OP
    • Yeah thanks...i thought it would be alot more i dont know 😄 I saw some videos on converting push/pull and it seems you need to "drill" the hole for slave(master) cylinder and buy some converter kit. On that front yoke clip i did not even know that is a thing and i need to source that(custom shops do not do that?) But anyway thank you for the info
