Hey guys, struggling to find some infomation about putting 3.5 or there abouts diff ratios in my GTR diff. So story goes I have a R32 GTR rear diff in my 180sx with a 2 speed glide with a KAZZ 2 way diff center fitted. It currently has 4.11 stock gearingit and im wanting to put around the 3.5/3.6 in it. I have access to a R34 GTR V-SPEC active LSD diff which is 3.5 ratio. Now my question is will the crown wheel and pinion from that fit into my R32 GTR diff? Or any other infomation about going to a lower diff ratio would be MUCH appreciated
Thanks.
https://www.sau.com.au/forums/topic/426467-changing-gtr-rear-diff-ratios/
ahh good question....not sure.
I do know the 34gtr front diff gears do not fit in the 33/34 casing/sump, but I am not sure about the rear.
Can you get the diff casing as well as the centre?
You sure about that Duncan? You have written 34GTR front diff doesn't fit in the 33/34 casing - surely it will fit in the 34 casing? I have an R34GTR front diff waiting to go in my R33 sump and have just been looking out for an R34 non V spec rear diff to go with it - I know some R34 GTRs over here have put R33 diffs front and rear to lower the gearing so I have always assumed that the reverse was possible.
I think there is a good chance it won't fit. The Nismo GT-Pro diff price list expressly says that their diffs do not suit the active LSD types. That would suggest to me that there is a lack of commonality between the pumpkins and the CW&P sets.
People who have swapped non-active diffs into V-specs have generally put the whole diff in, case and all, yeah?
It would seem obvious to me that if the OP has access to the V-spec diff, that he should obtain it, take it apart and see if the CW&P will bolt to another R200 centre (surely there's one lying around that you can access). If it will do that, then it will fit your diff too. Oh, unless there's also some difference in nose length or whatever that might also cause trouble, but you should also be able to check into that upon dismantling the diffs.
  • Like 1
You know, there are so many wrong things in my post that maybe I should stop drinking and typing. The correct statement is:
r32/r33 ratios (4.4 and 4.1) will not fit in the r34 front diff casing (3.5).
I know you've said it has been done, but they must have either modified the casing or used the 32/33 casing/sump (they bolt on the block fine). The 32/33 crown wheel/centre is too large for the 34 casing.
Correct :)
Although it's more then point that Nismo do not make a GT Pro to fit a Vspec A-LSD... So it requires a swap out with a non-Vspec.
At least that's with a R33.
Correct :)
I just did this conversion two weeks ago. I also needed shafts AND my V spec bolt pattern did not line up with the flanges that Nismo supploed in the kit. Both were a 6 bolt pattern but not the same size.
How sure are you on this? I bought a brand new R34 GTR sump/diff and was going to fit my crown wheel and pinion and lsd centre from my R32 GTR front diff into it.
I had no idea that the casings were different between models
Yep that is exactly what I tried. The casings are different.
I have just done a search and the part numbers for R32 and R34 GTR front sump/diff casings are the same (3842003V00).
I might give fitting it a go and I'll report back with how it goes
Please do report what you find - I have a diff swap planned and would like to know how you get on!
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
    • Can you covert an R32's AC from r12 to r134 if the compressor/hoses etc are still all good? Pretty sure on my car the AC was degassed when it was imported  to remove the naughty r12 and save the ozone layer, and the fancy climate control system just blew air around. Was happy to drive the car with windows down back then, but now I am old and need to be kept cool
    • Just to circle back here, I've sold my automatic trans to another Stagea owner in OH.
