hey all, iv had a problem with my knock sensor, it retards the ign timing sometimes on idle( between 1-15 mostly sits around 7 degree), but when driving the car felt normal.
I turned on the car today heated it up idled fine, i started to drive and timing dropped to 2-5 degree under load, it even hit 0 it couldnt be driven, but on idle it was okay.
I ran it through a scanner and it came up with the code 34 knock sensor earlier today, but after today im not sure if it would doing this from just the sensor being off, i feel like it might have skipped a tooth on the belt. Anyone had the knock sensor problem before?
Edited by HungarySkyline
https://www.sau.com.au/forums/topic/426473-knock-sensor-problem-rb20det/
I did. One of my sensors was ALWAYS reading knock between 0 - 20 non stop never a flat line. Pulled off the wire, trimmed it and reattached it and the problem went. I warn you though, it is an absolute flamin mongrel of a f**k to reach. I kid you not, Ive done my clutch, Ive done my timing belt, Ive done my turbo and the worst out of everything was trying to get to the sensor and unplug the wire. If its a code error you might have a faulty sensor. I suggest if you recently did your belt, pull it apart and ensure everything is lined up. One tooth won't cause engine damage, usually, but it will hinder performance terribly. Valves will not be truly sealed when it should be.
I hope your sensor isn't damaged. You could simplify the task greatly if you pull out the plenum and runners. Its a shit job. From what I know, you CAN run on one sensor. Try unplug one, again good luck, and see how it goes. You gotta squeeze the connector and pull out.
  • Like 1
  • 1 month later...
my gts4 I had ages ago had knock sensor code come up every now and then , ignored it as it ran pretty good and then I had to rebuild the motor due to no1 piston melted. -was running lean
I replaced one on a different gtst when replacing the cracked head here a photo to show ya where they are:
