esky_mad Posted June 5, 2013 Share Posted June 5, 2013 Hey guys, Picked up an R33 VLSD and matching half shafts. Which side does each respective shaft go into ? Obviously I have one long and one short. The shorter shaft has a C clip on it, is it difficult to get the shaft in with that clip on the end ? Should the longer shaft also have a clip ? Any help is much appreciated, Cheers. Link to comment https://www.sau.com.au/forums/topic/426478-r33-half-shafts-which-shaft-goes-where/ Share on other sites More sharing options...
GTSBoy Posted June 5, 2013 Share Posted June 5, 2013 Both should have c clips. The correct side to put thenm in is easy. Just take a look in each hole with a torch. You'll soon work it out. Link to comment https://www.sau.com.au/forums/topic/426478-r33-half-shafts-which-shaft-goes-where/#findComment-6879432 Share on other sites More sharing options...
esky_mad Posted June 6, 2013 Author Share Posted June 6, 2013 Ok figured it out. Longer shaft goes on the right side (vent tube side) Shorter goes on the right Longer shaft does not have a provision for a C clip Link to comment https://www.sau.com.au/forums/topic/426478-r33-half-shafts-which-shaft-goes-where/#findComment-6880342 Share on other sites More sharing options...
esky_mad Posted June 6, 2013 Author Share Posted June 6, 2013 Shorter goes on the left * Link to comment https://www.sau.com.au/forums/topic/426478-r33-half-shafts-which-shaft-goes-where/#findComment-6881190 Share on other sites More sharing options...
