R33 Skyline
93 Gtst
Km 130400
Manual
Apexi Power fc
Apexi Hand Controller
3 inch Exhaust
Mag wheels (8 inch wide front ,10 inch wide rears)
Alarm with Remote start
Turbo Timer
High flowed turbo
Dual stage boost controller
Running 8 psi low boost 15 hi boost
Front mount Intercooler
High Flow fuel pump
Heavy Duty Clutch
Sports steering wheel
Tinted windows
Genuine Nissan floor mats
Rego Till Feb
No Rwc
I`m sure I've forgot something So don't be Scared to ask Questions ill do my best to answer them
Only Selling Due to Needing a bigger Car for the kids Been Driven As a daily Driver and is very reliable
$9000 ono
Contact Cheryl
Location" Morwell Victoria
230ea61d-73af-4331-9d4e-b34d05044962_zps
5c7b6104-02f2-4964-8cd2-f3555055f1b5_zps
Edited by iwantar33
https://www.sau.com.au/forums/topic/426489-for-sale-r33-skyline-93-gtst/
Any one at all I need this gone Make a fair offer
Mate what you may consider a fair offer for a quick sale will be completely different to everyone else's idea of a fair offer for the first model of the r33's, they still made the r32 when your car was around.
Considering the price of 33's ill give you a fair offer of $4000 for a quick sale. If not thats cool, I don't care, but a usual sale price for a series 1 r33 is between 5 and 6 thousand after about 3 or 4 months waiting time.
Hi, would you be interested in swapping for my 1998 Nissan Avenir Gt4Z Wagon? It's SR20DET, all wheel drive & fully optioned with an electric sunroof. To my knowledge it's the only one in Australia of 15 in the western hemisphere. It's gunmetal grey and basically looks like a mini Stagea. Needs rego but wicked family car. I have pics i can text or email. I'm in Penrith nsw Luke 0410050643
  • 1 month later...
  • 3 weeks later...
  • 5 weeks later...
  • 2 months later...
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
