hmmm... i think i pretty much got everything in correctly but i dont think the old stereo/cassette that was in my line had a wire directly to the battery... which is a ***er because my kenwood unit wont work (i think this is why it wont work im not too sure) as i cant find a wire to hook it directly to the battery... ive got it hooked up to some wire that on the old radio says "13.4v Back up" or something.
anyone got any clues on this one?
https://www.sau.com.au/forums/topic/4265-battery-wire/
there should most definately be a +12v wire there with a constant 12 volts... get a multi meter and test all the wires (mainly red and yellow ones) for constant 12v and accesories 12v.
Hope this helps.
Christian
https://www.sau.com.au/forums/topic/4265-battery-wire/#findComment-67947
well i think ive done it... it turns on... plays my mp3 cds and what not... whether or not its gonna short circuit or not wont be known til whenever it burns down :)
i just ignored the diag that was on the nissan stereo and plugged them into where ever until it turned on... but i forgot to earth it and when i did it turned on whenever it touched the metal... so i assume its hooked up properly lol
https://www.sau.com.au/forums/topic/4265-battery-wire/#findComment-67964
Guest GR33DyMANGO
instead of buying a digital multimeter u can just buy a test light, which is a pen looking thing with wire that connects to the car body(earth) and a little light in the pen. they r really really cheap. just go to a car shop like marlows(dont know if thats australia wide?) and it should be a few dollars:D
then just touch it on each wire and when the light turns on with the ancillary off(ie engine off) u have found the constant 12v positive battery wire u are after:)
https://www.sau.com.au/forums/topic/4265-battery-wire/#findComment-76166
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
