Hi, im selling my drift missile 1994 R33 Nissan Skyline GTS-T due to loss of licence on June 24th, it is not my choice to sell but as I won't be having my licence for a whole 12 months I won't be needing my skyline.
Below are a list of modifications done to my car...
-Forge positions ,
-GT35/40 Garrett turbo
-48ml waste gate with screamer pipe
-Spitfire coil packs
-High flow injectors
-Ported heads
-Cam gears
-Front mount inter cooler
-3 inch exhaust from back to front
-MT12 microtec computer (was going to change to Apexi Power FC but no point now
-Coil overs
-Castor arms
-Lock diff
-Lock bar
-HHD heavy duty brass button clutch (can handle up to 450 rwks's
-Tuffend gear box with Dog Selectors (not a dog box)
-Turbo smart boost tap
-HP 18 inch deep dish rims
-Tuned at 274 rwkw on 18pound boost or 340 rwkw's on 24 pound boost
-Just had service done
-Plugs
-Oil
-Oil filter
-Brand new water pump
-Pirelli P Zero racing tyres
In car DVD player with reverse camera.
-Nissan skyline R34 bucket seats
-Sub and amp
The car owes me more than 16,000, no expense was spared in the build of this weapon. Clock has 170,000 on it which is pretty good for its age but all the same due to all the modifications not much is left standard so I'd say the engine was about 40,000 ks old, had a compression test done a few days ago and was firing 100% on all cylinders, I have the paper work to show that as well. Car was tuned by CMV motor sports.
I'm not trying to sell you a car that's half dead so the bad points are as follows, front bar needs replacing other than that the car is tip top and built to last.
My price is 10,000 and please do not give me a stupid offer if you like the car message me on 0422131648 and make me a decent offer, if you wish to call, then call anytime after 5pm Monday to Saturday. Or email on [email protected]
The photos are too big to upload on here, I am happy to send them via email or message to willing buyer.
  • Like 1
https://www.sau.com.au/forums/topic/426518-weapon-r33-gts-t-300-rwkws/
  • 3 weeks later...
  • 4 weeks later...
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
