Hey guys,
Been doing some research onto ECU upgrades for when i go big turbo and hopefully run e-flex.
Just curious if anyone on here has one in their car and can give some feedback on how it runs and some information on the ECU. The blackbox website has not been updated since the M1 model!
Unigroup highly recommends the ECU and says works a lot better than the G4, which was their previous favorite ECU.
Price is about 1800 which comes with all sensors unlike the Haltech as far as i know.
NOTE - Apologies if i'm wrong with any of the above information and feel free to correct me!
https://www.sau.com.au/forums/topic/426519-blackbox-ecu-m3/
Spoke to Bobby today and he recommended I stick with the nistune I already have.
Actually surprised me he didn't try push the haltech onto me. + points to Jem in my books =D
Bobby and the boys at JEM will generally point you in the right direction... You can still run E-flex with it but you cant run full flex fuel (If that makes sense?)
https://www.sau.com.au/forums/topic/426519-blackbox-ecu-m3/#findComment-6880548
I understand what your getting at :yes:
Now for the blackbox, to see if its a good option or not.
I have only heard Unigroup pushing them / tuning them after consulting google. Maybe the ECU is too new.
https://www.sau.com.au/forums/topic/426519-blackbox-ecu-m3/#findComment-6880567
I'm currently running one but haven't had it for long so I can't say too much about. Fits standard 34 case with minor mods and the only thing I've noticed (so far) coming from an Apexi PowerFC is it does take a few more cranks to start. Otherwise the driveability feels better due to the better sized maps and customisation for idle, cruise, etc - but I guess that's with most newer ECUs with larger maps.
The ECUs are getting some traction now but are still a bit of a WIP, as you would expect - Yavuz and Mark are already on it relaying feedback back so I'll be expecting firmware updates.
Reason I went with a Black Box was I'm planning to go fuel flex (not eFlex) in the future, so it made sense to do it at the time. Yavuz never pushed me to ditch the Apexi while he was doing other work on the car, the discussion came about when I mentioned my plans for fuel flex and previous cars he's worked on which were running G4s.
https://www.sau.com.au/forums/topic/426519-blackbox-ecu-m3/#findComment-6880568
Rightio.
I have the first GTR version in my car at the moment (more may have been put in since). I went from a PFC to the Link G4 and the driveability difference was amazing. Now having the Blackbox in there i reckon it's that again. The snapiness and just how crisp it is is really leaps and bounds infront of the two above mentioned ECU's. I always had a few little issues starting on E85, with the blackbox it's first go every go.
I changed from the G4 simply because I ran out of input / outputs. Between the Ethanol Content sensor, Wideband, staging fuel pumps, oil pressure and fuel pressure safe guards, crank trigger, I simply had no more room.
Now, as far as I know, Yavuz is the only one that has this software (I could be wrong though), so if that's an issue for you, then this ECU may not tick all your boxes.
You're obviously in Sydney so if you're interested, by all means come round and take my car for a drive.
  • Like 1
https://www.sau.com.au/forums/topic/426519-blackbox-ecu-m3/#findComment-6880574
Excellent info there thanks #@Watchamacallit and #Piggaz
Just curious since it is new. What happens with the firmware upgrades, do you take it back to Unigroup and they just load it up / any extra costs?
Sounds like a good option and i'm very interested in it, I'm a bit different and don't really like to run what everyone else has and this sounds like a good way to jump onto new technology :D
Also i worded my first post wrong. I don't want to run just e-flex, i wanted to go fuel flex, which requires the sensor. Just to clear that up :)
https://www.sau.com.au/forums/topic/426519-blackbox-ecu-m3/#findComment-6880605
I can't imagine there being a significant cost for firmware updates, if any - but don't quote me on that :P
Also good to get Paul's input on that, since he's done the multi-hop and helps ease my own minor concerns I had about going the Black Box. Full speed ahead! (and saving money to go fuel flex...).
https://www.sau.com.au/forums/topic/426519-blackbox-ecu-m3/#findComment-6880610
I've spoken to Yavuz about that too. There will be updates and its just a simple download. Not sure if you have to go out there to have it some or through Daniels website. Ill ask when I'm out there next.
One thing I forgot to mention is how "revvy" it is in neutral. It's alike a farken motorbike! I've had to learn not to push the pedal down so far when heel-toeing.
https://www.sau.com.au/forums/topic/426519-blackbox-ecu-m3/#findComment-6880620
So piggaz your saying this black box is that far advanced to the link g4 in drivability. Like going from a PFC to a g4 terms faaaaark it must be a awesome ecu. I look forward to some more feedback.
Cheers Josh.
https://www.sau.com.au/forums/topic/426519-blackbox-ecu-m3/#findComment-6880871
Cheers Josh.
I was surprised too. There are no cough's, splutters, 'funny idle' moments.
Unfortunately, it doesn't have the "name" or "marketing machine" as some of the better known ECU's out there, so some might turn their nose up at it.
https://www.sau.com.au/forums/topic/426519-blackbox-ecu-m3/#findComment-6880882
Who is responsible for it? Like manufacturing and design? Certainly sounds the goods...
https://www.sau.com.au/forums/topic/426519-blackbox-ecu-m3/#findComment-6880895
The blokes name is Daniel.... Can't think of his last name. "Morris Tech" is his company. From what I can gather, it's just him designing all funky stuff like this. Yavuz asked a few of us what we would like in it, anything we could think of, it already had it! Haha
I also have one of his "ignitor replacements" on my car. Had misfire issues a few years ago, ditched the OEM ignitor box, ran this and problem solved. GTR_JOEY had the same issue, same part fixed it.
https://www.sau.com.au/forums/topic/426519-blackbox-ecu-m3/#findComment-6880913
I have just put one if these into my 25/30 which is still only on run in, going from an EMS (yes I know) to this was a huge difference in drivability - which used to do all sorts of funky stuff.
I will second the point on no funny idle moments also, you can go from flat stick and suddenly pull up with out rev hunting and the car feeling like its going to stall.
It's also good to be able to start the car and not have black smoke bellowing out the ass while its warming up or having to wash my rear bar every 5 seconds.
I have mine setup with 2 stage fuel pumps and eflex setup so I will be able to fill up whatever fuel I want. A bit more stuffing around if you want it to look neat, but happy with the flexibility it will have. Haven't had it tuned on full power as yet as I'm still doing my 1000kms on 98 for run in, but looks promising so far.
I was a bit edgy about going something new also but sometimes it pays to innovate and have a bit of faith
https://www.sau.com.au/forums/topic/426519-blackbox-ecu-m3/#findComment-6881133
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
