Update guys!
I had my blackbox fitted to my GTR (to clarify, these ecu's are known as N61 and not M3) and I am extremely impressed!!!
After discussing further with piggaz, he tried to explain the differences in terms of driveability and now I get it...the throttle is very blippy and revs faster (I know it sounds silly), cold starts are phenomenal and general cruising honestly feels like a factory car - this ecu was built for this application.
I had it tuned by Yavus and I am very happy with the end result, in fact, my car was the first where they mapped the boost level versus ethanol content which basically means that I cannot over boost on low ethanol fuel (another safety parameter) + I have the manual override boost switch for valet parking :)
All in all, this ecu is nicer than my vipec and more feature rich (win win).
Paul, am I missing any other detail which I have left out?
not yet mate - i'll run it low as its currently running e30, then i'll bump it up to e60 with caltex eflex.
yavus prefers that i dont run e85 (united) until i beef up the fuel system, he will then touch it up on the dyno.
That makes sense.
Bring it on :D
Not trying to bad mouth anyone or any products.. but alot of the issues you guys seem to mention sound tuner related to me? it doesnt make sense, also you can buy an expansion harness for the Vipec/link plug ins which gives you another few imputs/outputs and you dont even need it to run an external map sensor. the external mapsensor can be wired in through the old AFM wiring. simple stuff really :/
What issues are being mentioned exactly?
They probably dont have time to update their* site as the work speaks for itself. Unlike other company's and products who advertise the hell out of them selves so people think they know what their doing
True, I did mention in another thread that I could run additional inputs BUT the onboard 2.5bar sensor will not support >22psi which are the key reasons why I upgraded to the Blackbox. The other reason is that it records any data in case of an accident whilst in flight mode :)
Unigroup obviously pick up enough work without the need for further marketing which is an enviable position to be in.
The drivability issues, lack of input/outputs, the only issue thats mentioned which is an actual known issue with the computer itself is the powerfc's little glitch.
There work obviously doesnt speak well enough to promote it to the point were people are still going blackbox? wtf is that.
If they dont have "time" to update there website they obviously dont value sales highly. for every person that isnt in sydney itself that could be a potential buyer as they come across this thread and read the great reviews it seems to get.. the website provides f**k all information that would encourage myself or anyone interested to buy such a computer.
For the software download that is available on there website to not work is even more of a deterant.
No... no its not considering this black box ecu has apparently been around since 2008 according to the copyright on its website, 5-6 years and if you mentioned "black box ecu" to A LOT of people in the car scene across the country i'd happily put money on it that 75% of them have never heard of it and no idea about it. Mention Vipec, Link, Haltech, Motec, microtech to all of those people and 100% of them would have heard of them all some good some bad.
So the AVI on the plugin board which go to the factory AFM wiring were in use? The majority of those listed above also has onboard data logging in plugin versions. blaming it solely on the onboard map sensor only rated to 2.5 bar is a piss poor excuse. roughly 100-150 to put an external 3 bar map sensor in with out needing any additional wiring from the ecu by tapping into the factory harness.
Alot of the drivability issues mentioned in this thread i'd actually blame on people using the internal map sensors as the vacume/boost line running from the intake manifold is that long there is a delay. It is always best to run your map sensor as close to the pressure source possible.
Do that for me.. tell me how long is the vacume line to your map sensor with the black box ecu compared to when you were running the previous ecu?
I run a Haltech PS2000 in my car and have played with a couple others including the vipec, the drivability gains from the putting in an external map sensor as close as possible to the intake manifold is amazing. my vacume line went from being almost 2 meters running inside onto the internal map and down to 15cm's onto the external map sensor with no changes to the mapping made it drove 1000 times better.
My map sensor position hasn't moved more than 20 cms between the Link g4 and Black Box yet the BB drives a lot better. Care to explain that?
Considering Marko's Vipec had an on board map sensor and so does his BB it might have moved 200 mm max (board width)
It was my decision to move to the BB and that is it. For u to call it a piss poor effort really is piss poor on your part and who are u to criticize my decision making? Whether u choose to drive a GTR or Evo, I really don't care...as long as u are happy and I'd actually be supportive. Not everyone is the same I guess and to tarnish my decision or another brand is not cool.
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
