What abou the whole safety issue, iv heard some really bad thigs like if ur in a small crash the car basically explodes so ur farked.
do they go BANG easily????
Real life isn't the same as "The Fast and The Furious" :)
https://www.sau.com.au/forums/topic/42652-nos/page/2/#findComment-873960
haha yes... I would install naws anyday, but I am afraid of losing my passenger side footwell.
NOS is the product name for Holley's N2O systems, NX is the product name of Nitrous Express's system. ZEX is another maker of nitrous systems.
Also did you know that when you ingest viagra, it stimulates the formation of nitrous oxide in your blood vessels, making the body react the way it does. If you don't believe me.
NOS... its viagra for your car.
https://www.sau.com.au/forums/topic/42652-nos/page/2/#findComment-874113
lol viagra 4 ur car! lol
so its not that bad then? doent it burn with an invisible flame?
just that i was advised by heeps of peole at another forum that its far too dangerous to use, and basically i was going to die if i used it.???
anyone heard of that Cryo2 mod, the shot of c02???
https://www.sau.com.au/forums/topic/42652-nos/page/2/#findComment-874622
:P BAAAAAHAHAHAHAHAHAHAAA!!!!!!!!!!!!!!!!!!!!!!!!! :P
As with any engine, if you increase the power (via a bigger turbo or N2O) it will eventuallt break something.
Absolute bile. Go away.
Adrian
https://www.sau.com.au/forums/topic/42652-nos/page/2/#findComment-874676
This is a much simpler system and is used to chill the intake temps. (think water injection infront of the intercooler mod) It wont really give you lots of extra power (like N2O) but will chill your intercooler big time and stop detination (so you could run a little more timing or a little nore boost without detination).
You may have seen this at the start of 2fast 2furious when the skyline pulls up ready for the big race.
https://www.sau.com.au/forums/topic/42652-nos/page/2/#findComment-874716
very much so yes. naws is only legal in a few states in the US as well.
pressurised co2 is used to cool down fuel lines and intercoolers, its a simple system that uses simple chemistry... ie, cooler the air, the higher its density, therefore more oxygen molecules.
i think it's illegal to carry any pressurised cans in a car unless they are fire retardants. not sure.
https://www.sau.com.au/forums/topic/42652-nos/page/2/#findComment-874984
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
