R31 Wiring Adapter/loom?
GXE23
 Share
G'day all,
Was going to tackle my stereo system today consisting of Door speakers, Rear Amped 6x9's, Sub, Headunit & Amp.
After learning earlier today that I'm going to HAVE to re-wire my door-speakers, this has set me back a little as I need to get 14g speaker cable.
I feel completely stupid asking this, and I'm certain I've just over-thought on it and have ended up questioning what I think is correct:
I can remove the adapter that's clicked into the stock unit pictured here: (As it holds no use as when I removed the stereo, it's been replaced with one from a wreckers due to writing on the parts in marker etc etc.)
I've done stereo installs on ALL my cars but have never come across this, as every stereo I've removed/replaced has always been factory standard.
So I plan to re-wire it to the new loom on the Pioneer DEH Headunit going in, as this is how I best know about doing installs.
It's safe to cut as close to the stock adapter/harness pictured here, and go about wiring these wires to the new harness that came with my Pioneer headunit?:
FINALLY
Can anyone tell me which colour is ACCESSORIES/BATTERY/ILLUMINATION on a 1989 R31 GXE Skyline, or supply a Stereo Wiring Diagram for one? As I've searched almost ALL day even thoroughly, through sticky threads with little to no luck.
Thanks in advance.
I don't really understand that question, yes you can unplug it, if you mean will it affect anything, then no it wont.
You don't have to cut into the harness, most auto stores will have a narva 8 pin connector that will fit it, so you can use the standard power and grounds.
Since your only doing the front speakers from the head unit you can also unpin the standard speaker wires and put your new ones in using the pins that came with the connector( there should be a male and female connector in the same pack). It shall look nice and standardish.
I cant remember which wires are which off the top of my head and my car is about 500kms away so I can't check.
But i deduce from your picture that perhaps the two pins on the far right top and bottom are grounds and the one on the top left is a power source of some sort, i'll guess constant because it appears to have a fuse in it.
You should invest in a multimeter (if you don't have one already), a gregorys manual and check out r31skylineclub.com
 Share
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
    • If it has had a code in the recent past, the code should still be there waiting to be read.
