Hey guys, I have a 32gtr. The engine has everything under the sun done to it. It has -5s and makes great power. The problem is not great power figures it's low down power out of corners. I'm thinking this problem may be due to 280 cams in it. What do you guys think? The car has been very finely tuned so I don't expect this.
https://www.sau.com.au/forums/topic/426530-need-more-down-low-for-the-track/
It is a2.6ltr, 98 octane fuel with octane booster the tune was done by dr drift then by cosmic performance.
It sound like people are making great power and response from the stock cams. But I'm not sure they would use all of the rev range up top that the engine was built for...
Cheers guys!
Have you considered using the next gear down, to keep the engine in its power band?
What if you're at 4000 in second... Not quite enough on a massive cammed 2.6 with 5's to really get a wriggle on.... You're not gonna go back to first are you?
The boys pretty well have it nailed for you mate. Jew brew, smaller duration cams, this is depending on what has been hacked out of the head as well, a good free flowing exhaust, a good cold air system and some time on the dump with a set of cam gears. Failing that, a 6266 is a good option.
Cheers guys!
So what are you spinning the motor up to exactly? Because realistically you wouldn't build a motor to spin to 9,000rpm+ and then put -5s on it as there is no need.
My stock cams were fine to 8500rpm for example with -5s... Power had not fallen off at all.
280s are madness either way for -5s, terrible match
Potentially get flamed for suggesting this. Oh well here goes anyway.
Guys above I believe are on the money. DO this ^
do you run a Torque/split controller ?
considered replacing your OEM G sensor ? with a Do Luck Tarzan G or the Midori unit.
the mines 34GTR is so responsive coz of the diff ratios despite the 2530's on RB26. Either a 4.11 or 4.4 ratio would be off tap, obviously the top end end would be compromised a bit, but who cares
mines GTR response is unreal
Edited by discoPumpkin
You are all missing the point. Odds are it would be cheaper to get the thing through the corners quicker...then you have more revs on exit and more revs means more power.
So what suspension and tyres/rims size are you running. Cams or no cams -5s can work perfectly well on a 2.6L so if the thing is laggy on exit I think you need to get through the corner quicker
Totally agree.
Driving style is another.
How long is a piece of string.
If your at a tight track you may suffer but at a faster track it may be perfect. Set up is about compromises and wont be perfect for every corner. Just keep trying to get your lap-times down. I would be listening to Roy before i go touching the engine.
Yeah but massive lift big duration cams (280*) are made for a gt42 45 55 ect sized turbo. Just not really suited to smaller twins. Twin 3037s and a 1/4 drag strip is a different story. Tomei type b's are tried and proven with -5's on the track and even a drag strip strip. As R31Nismoid said -5's and 280* cams are just a extreme mismatch. I do also agree with roys comment to a extent as well.
Cheers josh
omg, OP never once stated getting a bigger engine was an option, oh and the RB26 has to be one of the best know motors for track use for it's mid to top end power, reliability and revs.
I agree with Jim and changing the diffs, and the other guys in swapping the cams, and finally making sure it has good soft tyres for grip to enter the corners fast as poss. That will make a big difference to response
Thanks for all your responses guys. I know the cams are to big (they were in when I got the car). I run semi slims and custom coilovers on the track. I'm not sure that corner speed is the problem. Eg on sandown in the tight section it feels like I should be cornering in third but find that to get good power down out of the corner I need to be in second. Second I need to rev the car to 9+g and third is a bit sluggish out.
Would my engine specs help?
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
